Advice On 18v Cordless Tool Set? - Tools - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 02:05 PM   #1
Advice on 18v cordless tool set?
Hey all - hoping for some advice from those that have been there...
Ryobi 18v cordless kit; drill/driver, circular saw, sawzall, etc. ~8 years old. On 2nd set of batteries ~4 years old. I am a 'weekend warrior'. Set can get lots of use for a while, then sit untouched for while.
Its been a great set, but batteries no longer hold a charge. Just bought a new charger (from recommendation of tool guy at HD), but it did not do the trick. So...
Am concerned the tools themselves may now be worn-out. Don't want to throw away $60 on a 3rd set of batteries only to find tools are finished. Am not opposed to keeping the new charger and getting new batteries if they will add life to the set.
Any experiences from y'all? What would you do?
Your thoughts are much appreciated!
ChrisWhitley is offline   Reply With Quote
Old 03-19-2012, 03:03 PM   #2
Rewards Points: 1,456
No doubt it's the batteries.
I would take the charger back as I'll bet that's not the problem.
Get the batteries, charge them up, use them. Charge them only when they are nearly dead. Do not leave them on the charger.
ktkelly is offline   Reply With Quote
Old 03-19-2012, 03:14 PM   #3
Love for Construction
<*(((><'s Avatar
For your use you described I would only purchase lithium ion batteries thy will last longer than nickel cadmium batteries with infrequent use.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-19-2012, 07:07 PM   #4
Rewards Points: 512
pick up a ridgid combo kit, lifetime warranty
princelake is offline   Reply With Quote
Old 03-19-2012, 07:17 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the batteries are toast, not neccesarily the tool itself though they may need new brushes in the motor. its definitely not the charger, either a ill informed hd staffer telling you that.. or they do know and are simply cheating you out of your money. try some new batteries first
rigid does have the warrenty however their cordless gear is hit or miss. of the 3 cordless rigid tools ive owned.. ive had 2 batteries go bad very early in their life. but ive never had that problem with makita or bosch
woodworkbykirk is online now   Reply With Quote
Old 03-19-2012, 11:47 PM   #6
In a little over my head
Rewards Points: 706
Sounds to me like you need batteries. I'm not a Ryobi fan, but if you still like the tools, there may still be some life in them. Try a battery. Battery Depot has good prices on 'em, IME.
ratherbefishing is offline   Reply With Quote
Old 03-20-2012, 11:20 AM   #7
Rewards Points: 768
I bought a craftsman combo set (drill and impact driver) for $100. They've been great. I forgot to take the batteries inside this winter, which I'm sure isn't helping the life span.
My brother owns a dewalt impact driver and says it's the best driver he's had.
cibula11 is offline   Reply With Quote
Old 03-20-2012, 12:44 PM   #8
Brother is right.
I've owned a DeWalt 18v VSR hammer drill for years. Used very heavily, day after day, on construction sites drilling literally thousands of holes in a variety of sizes (1/4" to 2+")
Only issue was a broken trigger, after some 10/12 years, which was a $45.00 fix.
Old 03-20-2012, 03:49 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
If your new charger is the ItelliPort Charger, then it will charge Ryobi Li-Ions.
Since you have all those Ryobi tools, it would be cheaper to just buy some new Ryobi Li-Ion batteries.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-20-2012, 07:34 PM   #10
bob is right. i believe ryobi has designed their lith ion batteries to be compatible with the older 18v nicad models. its something milwaukee came up with then dewalt copied along with ryobi
Old 03-20-2012, 08:05 PM   #11
Tool Geek
PaliBob's Avatar
From what I see the new Ryobi Li-Ion Batteries are compatible, as long as you have the new charger.
http://www.amazon.com/gp/product/B00...-ion%2Cbarrery
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-20-2012, 08:49 PM   #12
I'm Your Huckleberry
Rewards Points: 2,270
MAKITA!!! It'll drive Dewalt backwards.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-21-2012, 06:23 PM   #13
doc your sorta on the right track.. makita will drive over it, then back over it get on its way and laugh at it
makita cordless hands down, just about every trade publication that reviews tools rates makita in the top 3 every time, being beaten by panasonic or festool
Old 03-21-2012, 07:29 PM   #14
Rewards Points: 512
i bought a makita 5 pc kit 2 years ago. what a pile of junk! after about 6-7months everything was falling apart and batteries werent holding a charge for long. i sold the kit and bought the ridgid x3 kit and its been getting beaten ever since. i have to say the makita tools are wayyyy more comfortable to use and feel great in your hand and evey light compared to other brands especially the x3 ridgid kit. not long after i got my x3 kit the x4s came out and i was pissed. they fixed the bricks they called tools. i took the lifetime warranty over comfort but now i want the x4s haha
Old 03-21-2012, 10:07 PM   #15
the problem with the rigid cordless gear is that they keep having problems with the earlier lines.. as soon as they re-engineer something the older stuff is no longer available which makes it harder to get parts or batteries if you have an older model.
the other major companies keep making the older stuff but make minor adjustements to them so everything in the line is compatible. you probably just had a bad batch of makita or arent the type who takes care of your gear. ill take makita over rigid cordless any day
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 02:31 PM
PEX Press tool? Ultrarunner2017 Plumbing 5 05-12-2009 11:43 AM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 01:41 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
