Adding Electric Start To Makita Generator - Tools - DIY Chatroom Home Improvement Forum
Old 12-05-2008, 09:26 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
adding electric start to Makita generator
i have a makita G6100 generator, i was wondering if i can easily add a battery to make it electric start, it has the battery charging terminals on it
Mr Chips is offline   Reply With Quote
Old 12-13-2008, 10:45 AM   #2
Safe, Most of the Time!!
brokenknee's Avatar
I know I considered the same thing with the generic generator I have. When I call the company they told me I couldn't do it.
I am not sure why it wouldn't be possible. There is the "knock out" for the starter to mount to. I would find it hard to believe that they would use two different ring gears for basically the same generator.
Maybe some day I will look into it further. For now it starts just fine with a few pulls on the cord.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 12-13-2008, 10:03 PM   #3
homework's Avatar
It would depend if this is an option available for your generator.This would require usually: the mounting plate for the starter, a geared flywheel, a starter clutch or bendix, the starter motor, battery and cables,battery mounting hardware, way to keep battery charged either thru generator itself or engine alternator.If generator was manufactured with this available as add on it may be available as a kit. If not it would be hard to impossible to add.
homework is offline   Reply With Quote
Old 12-14-2008, 06:51 AM   #4
brokenknee's Avatar
I do have a geared flywheel. Starter clutch or bendix? Aren't they part of the starter motor? Cables are cheap enough to purchase and the battery can be kept charged through the generator itself. Mine has the battery charging option. You can always come up with a presidential solution for the battery mounting hardware.
Mine was not available as a kit. But I know I have the ringed flywheel (I looked). I will have to look at the mounting plate for the starter. Mine is up at the lake right now, so will check on it next time I go.
Old 02-16-2009, 08:34 PM   #5
i've just bought a makita generator G6101R that has electric starter. Does anyone know what kind of battery i should get for this generator? I wonder if i can use regular car battery for it?
thanks
tundra2007 is offline   Reply With Quote
Old 02-16-2009, 08:54 PM   #6
brokenknee's Avatar
Get a battery for a riding lawnmower, a car battery would be to large.
Old 02-16-2009, 08:55 PM   #7
Mr chips u need to find out what kind of engine is on the gen and or got to makita for parts. Tundra you only need a small battery ie motercycle or atv but do yerself a favor and get a battery tender to keep it charged
bb45 is offline   Reply With Quote
Adding Electric outlets to bedroom with plaster walls jimmyfloyd Electrical 13 11-07-2008 04:20 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 05:25 PM
