Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 01-04-2013, 04:11 PM   #1
Cricket11b30's Avatar
46-460 Delta Lathe
Good morning I have a really quick question for you, I recently purchased a delta 46-460 midi lathe two weeks ago and last night I was sinning a bowl 8 inches in diameter. when I give it pressure the bowl slowed down almost to a stop. I am concerned that it might be the motor or is this normal? I could really use your help I just starting learning to spin and I feel in love with it and the machine.
Cricket11b30 is offline   Reply With Quote
Old 01-04-2013, 04:30 PM   #2
46-460 Delta Lathe
Just some guesses.
Dull chisle.
Trying to make to deep a cut.
Trying to us it with a long under sized extention cord.
Using a 15 amp circut.
Trying to run it where there was to small a wiring feeding the circut.
Cricket11b30 (01-04-2013)
Old 01-04-2013, 04:35 PM   #3
46-460 Delta Lathe
Thank you I will give all those a try I think I need to change the breaker anyway because I keep tripping the same one with my miter saw.
Old 01-04-2013, 04:41 PM   #4
46-460 Delta Lathe
Where are you trying to run the lathe?
Time and time again I see DIY's running way to small a wire to a shed or garage thinking I only need one outlet and a light and want to save money then end up adding stuff one and have it not working.
Old 01-04-2013, 04:57 PM   #5
46-460 Delta Lathe
I am running it in the garage, The garage is attached to the house so there is no shady wiring running from point A to point B. I just recently I started trip the breaker it never happened before I I am going to run out in a few to lowes and purchase a stronger breaker and change it, out like you suggested hopefully that will help.
Old 01-04-2013, 05:05 PM   #6
Electrical Contractor
46-460 Delta Lathe
You just can't buy a stronger breaker.
The breaker has to be sized for the wire, so if you #14, then you can only install a 15 amp breaker.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-04-2013, 05:08 PM   #7
46-460 Delta Lathe
Hold on, what sized wire is running to that circut?
If it's 14-2 you can only have a 15 amp.breaker.
If it's 12-2 you can use a 20 amp breaker.
Using to high an amperage breaker and the wires can melt before the breaker ever trips.
Old 01-04-2013, 05:29 PM   #8
46-460 Delta Lathe
Ok this is what's have bare with me I am just a little drill sergeant not very skilled like you guys just enjoy doing things my self with a little help
Old 01-04-2013, 06:18 PM   #9
46-460 Delta Lathe
I sent a pick I was wondering if you could give me your best suggestion
Old 01-04-2013, 07:24 PM   #10
46-460 Delta Lathe
Permission to recover drill sgt?
You have 20 amp breakers and can't exceed that size.
You need to find out why the breaker is tripping.
Old 01-04-2013, 07:41 PM   #11
46-460 Delta Lathe
To funny lol so do ou think it would be a good idea to just replace with the same size
Old 01-04-2013, 07:46 PM   #12
46-460 Delta Lathe
You don't have a choice but to change it for the same size.
They are cheap enough, but it may not be the problem.
Old 01-04-2013, 07:48 PM   #13
46-460 Delta Lathe
Because it just started doing when I starting put my wood shop to get her and it only does it when I use my miter saw and once when I used my table saw
Old 01-04-2013, 07:54 PM   #14
46-460 Delta Lathe
You need to check the circuit for a loose connection from the panel to all the receptacles.
You should also check you saw on another circuit to make sure that is not the problem.
Old 01-04-2013, 07:57 PM   #15
46-460 Delta Lathe
Will do thank you
Stanley sells off the Delta division dtsman General Discussion 0 01-07-2011 07:43 PM
220 vintage lathe wiring?? stratton Electrical 5 09-02-2009 08:56 AM
Glacier Bay, Peerless, Delta Yoyizit Plumbing 2 03-11-2009 12:20 PM
concrete basement - installing laminate on delta SDG Flooring 1 12-29-2008 09:10 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 04:29 PM
