3/32nd Masonry Bit, Does It Exist? - Tools - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 08:30 PM   #1
3/32nd Masonry Bit, does it exist?
Hi guys,
I'm installing house numbers over stucco and the instructions call for a 3/32" drill bit-- I can't seem to find a masonry bit that small. Does anybody know where I can find one? I checked all the big stores (Home Depot, Lowes, Sears, etc.) I live in the LA area (SF Valley)... or any online stores work too. Thank you!
Much appreciated,
-Mike
Mike A is offline   Reply With Quote
Old 05-11-2011, 08:40 PM   #2
Learning by Doing
Leah Frances's Avatar
Googling "3/32 masonry bit" produces lots of choices including Sears. Your local one just didn't have what you wanted.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-11-2011, 08:56 PM   #3
Yes, I've tried that, but with quotes and without quotes. It gives me lots of links, but when I click on them I only see black oxide bits in that size or drill bit sharpeners in that size, but never actual 3/32nd masonry bits. Thus, sifting through google results on this particular search is what I can only imagine a brain aneurism must feel like.
If you did actually find anything on google and could paste the link here, I'd greatly appreciate it! Thanks again!
-Mike
Old 05-12-2011, 01:50 PM   #4
Household Handyman
Rewards Points: 1,408
Mike, I've been in industrial maintenance for 38 years, and am now with a company that sells fasteners and mill supplies--I have never seen a 3/32" masonry bit myself. That doesn't mean someone does not have them, they would be new to me. These would be so small, you would really have to careful using them. Go to a local "big apron" store and look a the "Tapcon" drills, in the nut/bolt dept., to see if there is something you can use.
The Following User Says Thank You to Thurman For This Useful Post:
Mike A (05-12-2011)
Old 05-12-2011, 04:59 PM   #5
Rewards Points: 154
i have one at home, came in a set
awdblazer is offline   Reply With Quote
Old 05-12-2011, 05:05 PM   #6
Do you remember where you bought the set or the name of the set? Thanks!
Old 05-16-2011, 12:50 PM   #7
Nevermind
Ended up buying a 1/8 bit and using anchors.
Old 05-16-2011, 09:33 PM   #8
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
smallest tapcon bit is probably 5/32
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 05-16-2011, 09:44 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't need a masonry bit to drill stucco.
XXX
I need a very very high quality masonry bit - Help Needed badly. MooseWoodworks Tools 5 03-13-2011 09:28 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Low Profile Masonry Receptacle box? Lovegasoline Electrical 0 12-02-2009 02:01 PM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 01:31 PM
Sealing above steel lintel in masonry building? mkchicago Building & Construction 1 02-28-2007 08:23 PM
