2hp / 6gal Compressor w/ framing nailer
The small ones won't hold up to a contractor's daily use but like tgep said, it should be fine for what you plan on using it for. Also, larger compressors require larger circuits to run and you may have problems in your home.
You'll be fine with the small compressor and a framing nailer.
Terry
