2 Cycle Engine Repair - Tools - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 11:59 AM   #1
Rewards Points: 150
Unhappy
Just found out that my 1 year old Poulan leaf blower has a fried exhaust cylinder. Kinda pisses me off, but, what can you do.
Repair shop wants $180 to fix, as it is not covered under warranty (says because of poor oil/gas mix). Paid $200 for it new. Blah...
I found the complete piston/cylinder kit from Poulan for $35.
Has anybody done this sort of repair before? I have not, but am very mechanicly inclined, and have worked on my truck and car in depth. Looks like it would be quite simple.
Any insight appreciated.
TJ_in_IL is offline   Reply With Quote
Old 11-09-2010, 02:12 PM   #2
Rewards Points: 472
i have work on many of those 2 cycle and most are not that had to work on . Just keep thing's in order like i belive that is is a pined piston which mean's that the rings don't move around the piston . Their should be a pin in the ring slot. Put the ring's so that the end's are their of course the ring will be the ring toutch's from both ends . Cant go in any other way Should be 2 ring's ? they go to the back of the exhaust port's so that they don't catch the port edges. Also the end cap will go on only one way. It probly has needle beiring's . Use a paste grease to keep them on the rod end and the rod cap . Make sure that the rod cap fit's togother. It is cut so that if you get backward's it won't look right and wont go togother. Other that that not anything to it. Oil the piston with a little oil and some in the ring slot. Those motor part's used to come out of Missouri yrs ago. good luck
del schisler is offline   Reply With Quote
improved 2 cycle engine oil? oletrkguy Landscaping & Lawn Care 0 11-08-2009 12:50 PM
techumseh engine repair johhnyx Landscaping & Lawn Care 1 07-14-2009 04:05 PM
Small engine repair tripower Tools 2 07-09-2009 04:28 AM
Small Engine Repair Two Lamentations General DIY Discussions 3 01-30-2009 03:10 PM
small engine repair oletrkguy General DIY Discussions 24 12-08-2008 06:04 AM
