Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-04-2012, 11:59 PM   #1
SimpleJack's Avatar
1HP 125 gallon Compressor. What tools can I use?
1HP 125 PSI Compressor Craftsman single tank
I need to cut off my exhaust pipe on my car and I need a Air cutting tool. Is my compressor enough to run this small tool? maybe not at max power, but could it be enough to cut off a metal pipe?
I borrowed one from my neighbor, but it's blowing mass air from the rear exhaust on the tool and loosing all the air pressure when I push the trigger.
I was thinking about buying one for $10 from harbor fright and maybe I wont have this same problem?
http://www.harborfreight.com/3-inch-...ter-47077.html
What small tools can I run with this compressor beside a nail gun? Not looking for non stop action, but enough to eventually get the job done as it recharges at a semi decent speed compared to other cheap compressors I have used.
SimpleJack is offline   Reply With Quote
Old 09-05-2012, 12:22 AM   #2
Oldguy
Rehabber's Avatar
You need a large air compressor to run a muffler cutter. Try a sawzall with a fine tooth blade instead
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 09-05-2012, 12:29 AM   #3
Size, HP, PSI have nothing to do with a tool working or not, It's CFM you need to be concerned with.
Sounds like it's the tool that needs rebuilding and nothing to do with your compressor.
Old 09-05-2012, 12:32 AM   #4
http://www.engineeringtoolbox.com/ai...ols-d_847.html
Old 09-05-2012, 12:56 AM   #5
SimpleJack's Avatar
Originally Posted by joecaption View Post
Just one of the tools I looked up from that site (Body Polisher) says it only needs 2 cfm, but looking at these tools online they need 3 to 15 cfm and it also seems I don't have enough to run my blowgun which I have no problems running, not constantly though, but still. Good link to atleast get a semi general idea of what I can use.
But my compressor is rated at SCFM Use At 90 psi 2.4 SCFM so i guess I just don't really have enough and that tool might also have issues as there is almost as much air coming out the back as there is coming out of my blowgun. It's a auto shop tool and it's one that they use, so really I don't know what the deal is with it.
Looks like I'm stuck with only using nailers, staple guns, air blower and possibly a small air ratchet.
Thanks for the quick help everyone.
I just need to invest in a $400 air compressor to have any fun..
Old 09-05-2012, 02:13 AM   #6
You don't have a 125gal compressor!
Hardway is offline   Reply With Quote
Old 09-05-2012, 02:16 AM   #7
SimpleJack's Avatar
oops haha
Old 09-05-2012, 03:24 AM   #8
That being said not much you can run with the compressor you have. I have a 3hp 60gal it puts out 12cfm. I do basic to heavy car repair and it has not failed yet.
Old 09-05-2012, 09:25 AM   #9
jschaben
Pick up chain cutter. Does a better job anyway.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Antique tools...built to last! spaceman spif Tools 11 09-13-2011 08:49 AM
Tools for a newlywed beginner mephysteaux General Discussion 9 09-24-2010 11:43 PM
Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 whataboutj Landscaping & Lawn Care 25 05-13-2010 11:01 PM
Is a 40 Gallon water heater electric enough for a 1 bath house (2 people). twilightcall Plumbing 6 08-06-2008 10:11 AM
