1HP 125 PSI Compressor. What tools can I use?
1HP 125 PSI Compressor Craftsman single tank
I need to cut off my exhaust pipe on my car and I need a Air cutting tool. Is my compressor enough to run this small tool? maybe not at max power, but could it be enough to cut off a metal pipe?
I borrowed one from my neighbor, but it's blowing mass air from the rear exhaust on the tool and loosing all the air pressure when I push the trigger.
I was thinking about buying one for $10 from harbor fright and maybe I wont have this same problem?
http://www.harborfreight.com/3-inch-high-speed-air-cutter-47077.html
What small tools can I run with this compressor beside a nail gun? Not looking for non stop action, but enough to eventually get the job done as it recharges at a semi decent speed compared to other cheap compressors I have used.
