12 Volt Vs 18 Volt Cordlessdrill/driver.. What To Get? - Tools - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 09:39 PM   #1
12 volt vs 18 volt cordlessdrill/driver.. What to get?
Hi everyone! I'm in the market for a cordless driver/drill. I'll be finishing my basement this summer and was wondering which will have the power to do the necessary work. I have a corded driver/drill that I have been accustomed to working. However, those were small jobs that did not require much mobility. In your opinion, is the 12v sufficient for what I'm doing? I like how it is much smaller than the 18v and cost a bit less as well.
I tried searching the forum for a similar topic but did not find anything that discusses this. Please don't be mad.
hnd83 is offline   Reply With Quote
Old 04-17-2011, 07:17 AM   #2
Rewards Points: 121
Worked in a commercial cabinet shop for years, making large items like bank teller lines and other high end items. Used a 12 volt Dewalt and it was always powerful enough for a LOT of driving, hole cutting, installation, etc. Never let me down. 12 should do just fine.
JoeLena is offline   Reply With Quote
Old 04-17-2011, 12:46 PM   #3
If you're a weekend warrior, then a 12v model should work fine for you. I own a full range of Bosch ones, but then I make my living with my tools.
VIPlumber is offline   Reply With Quote
Old 04-17-2011, 12:57 PM   #4
Learning by Doing
Leah Frances's Avatar
I'm in the 18v camp. I've got a set of Dewalts from Costco and the original batteries are still going strong 4 years later. I bought several extra batteries and chargers to keep around the house. I find for using the angle grinder for extended periods, I run through batteries pretty quickly. But for everything else -
BTW - my Dad picked the 12v set because: "I'm old and like having an excuse to stop working."
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-17-2011, 01:23 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
when an 18 volt battery weighed a couple pounds, I would try to make an argument for a 12 volt. Now that the 18V batteries (Li-ion) weight nearly nothing, I cannot see why one would bother with anything less. That was the last real disadvantage to the 18 V tools and no real advantages to a 12 V other than that.
Old 04-19-2011, 11:06 AM   #6
\Thank you for all the replies. After reading them, I've decided and purchased the makita 18v li-ion 2 piece combo kit as shown in the link:
http://makita.com/en-us/Modules/Tool....aspx?ID=24067
Used it one day so far and I gotta say, pure power! The impact driver is amazing! I drilled 4 - 1/2" holes through a 4x4 and each time it went through it like butter! The battery charged fully very quick and last pretty long so far. Does anyone here have the same kit? How are they over the years?
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
