Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-19-2007, 09:22 PM   #1
12 amp circular saw - how powerful is it?
I'm thinking of buying the ryobi 12 amp circular saw for $49. Can it saw 4" thick wood?
handbanana is offline   Reply With Quote
Old 04-19-2007, 10:49 PM   #2
No. Assuming this is a 7 1/4" saw, it'll cut about 2.5" max depth. You a dang big circular saw to cut 4x4s in a single pass. Just make lines on both sides with a square, and cut one side, then the other to finish the cut.
NateHanson is offline   Reply With Quote
Old 04-19-2007, 11:33 PM   #3
Darylh's Avatar
If your looking for a cheap saw to have around the house to use once in a blue moon then it would probably be fine and Nate is right just make sure the deck of the saw is square with the blade in fact when you go to get one take a little square with you and check it.
Darylh is offline   Reply With Quote
Old 04-20-2007, 12:02 AM   #4
If you're going to use this more than a few times a year, or if cheap tools annoy you, then I'd pass on this, and look for a saw with an aluminum deck. You'll pay another $50, but those stamped steel decks are a real pain, IME.
Old 04-20-2007, 11:04 AM   #5
I used to own a cheap saw, which is gone all of sudden... make me don't like cheap tool no more... not just the $$... I waste time and effort to transport and the store the tool around, and finally dump it...
KUIPORNG is offline   Reply With Quote
circular saw rpm-is that the motor or blade rpm? airpwr1@graceba.net Tools 13 06-28-2009 07:28 PM
when buying circular saw from Ebay be aware to ask KUIPORNG Tools 4 05-04-2007 10:29 AM
closing circular duct steve6 HVAC 7 02-22-2007 09:06 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
Using circular saw boxer1-2 Tools 9 12-28-2005 09:19 PM
