yet one more insulation question
I have a 1925 two story home with minimal attic insulation. What is up there is, I believe, rockwool. The attic is about 75% floored and the insulation under the boards varies 6 inches to nothing. I have some remaining work to do up there before I have additional cellulose blown in. Can I add the new insulation on top of the floorboards or should they be removed first. I was going to take out the floor and remove all the existing insulation but the more I think about doing that the less I want to.:whistling2: Is adding the new insulation on top of the flooring a really bad idea? There will be lots of places with a considerable air space between the attic flooring and ceiling below. Adding the new insulation on top of the existing rockwool in the unfloored areas a bad idea also?
Thanks |
The dead air spaces are not a great R value, and they certainly lend themselves to air currents, which hasten the heat getting from warm to cold. Wood is not a serious moisture barrier, so it won't hurt, but it will leave air pockets and it, too, has a poor R value. There is no reason that I can see to remove the old insulation, unless it has been compromised by rodents using it to go potty, etc. If it were mine, I'd bust a hump to get the wood out of the way; you can likely re-use it somewhere, right? Cellulose is a good choice; put in as much as is appropriate for your area, but make sure the sheet rock will support the extra weight.
Mike |
Mike in Arkansas, I'm dealing with the same situation in my mom's attic. Her house was built in 1895 and has since been remodeled.
There are 4'x8' osb boards covering the floor of the attic. When I first went up there, I thought I would only have to seal everything up and add the cellulose. But not checking what was under the osb was bugging me. So I pulled up a few boards and more than tripled the amount of work I now have to do up there. All of the boards will have to be lifted and removed. But that's alright because my goal is to bring her heat bill down from $600+ per month to as low as I can get it. Under the osb is about a 2" to 3" gap between it and the top of the existing insulation. That's not good, as jklingel said. But the biggest problem I found was the gaps between the insulation and floor joists and the fact that none of the penetrations into the attic had been sealed under the osb. So there was (still is) air from the living space leaking up into the space under the osb and ultimately, into the attic. Another thing I found is that heated air can come up into the attic from the bays of the exterior house walls because there is nothing blocking the tops of those bays. I hope this is making sense. There are a lot of other things going on up there that need attention, but I guess what I'm saying is that if I were you, I'd pull up the boards in your attic and investigate. That way you can properly seal everything. Insulating your attic isn't enough if you're still losing heat or air conditioned air up into the space between the ceiling and the attic floor boards. Do you have a hatch that leads up into the attic? If so, how is the seal on it and is it insulated? |
Thanks again |
| All times are GMT -4. The time now is 09:14 AM. |
