Yet More Basement Questions - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-26-2011, 09:56 AM   #1
This may take a bit of explaining, so please bear with me. Our house sits on a south sloping lot, with attached garage to the north, and not a walkout basement, but full sized windows facing south. At the time of building, tar was sprayed on all of cement block that is under grade. Our basement slab is not attached to the walls, but has a small trench that runs the perimeter (floating slab design?). There is a drain in the floor itself, and another in the trench.
Our problem, the lot also has a few springs and the basement is damp, with dampness on the blocks, particularly the north wall, which is under the garage.
The basement floor has only flooded once since we built, and then it was only a small amount, after a very cold period. I have always thought it was because of possible ice build up in the drainage due to the cold.
I would like to finish the basement eventually, but it will be some time before money is available to do so.
I would like to do something in the interim so that the basement is more user friendly, with less dampness, mold and mildew. I have read good and bad about Drylok, and have seen concrete sealers referenced, but don't know any names or specifics.
While it seems the most often suggested action here is to waterproof from the outside with sealer, membrane, etc..., that doesn't seem a viable option for my north wall, either practically or financially.
So, are there any products out there that will work from the inside? Any ideas and suggestions are greatly appreciated.
Also, the questions about what happens later come up. Do I put up a vapor barrier later? How do I deal with the trench around the slab? I suppose those can wait, but I am trying to think ahead.
DocWard is offline   Reply With Quote
Old 06-26-2011, 10:45 AM   #2
Work Hard, Play Harder
Rewards Points: 212
If it helps; my inside is completely drylok'ed (previous owner) and I had drain tile installed by basement systems. My basement is still a never ending battle. I'm running two dehumidifiers 24/7, just to keep humidity ~60%
The water will eventually push right through; the drylok will make the basement look nice long enough to sell it (sigh).
IMO; based on my horrible experience; feedback here; books from the library; Holmes on Homes, This Old House, and other internet research, waterproofing has to happen on the outside with a proper drain at the base of the foundation (sitting on footing or next to it; I'm still trying to figure that one out); mastic tar; then felt; then mastic tar; then dimpled membrane. Run the drain to your sump or away from your property.
I am not in the exact situation; I have a detached garage and a walk-in. But my property is southern sloped and eastern sloped.
Whatever solution you choose; please share your results!
coderguy is offline   Reply With Quote
Old 06-26-2011, 08:35 PM   #3
Registered User
Rewards Points: 4,924
http://www.buildingscience.com/docum...gs?full_view=1
http://www.buildingscience.com/docum...ms?full_view=1
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
coderguy (06-27-2011)
Old 06-27-2011, 04:22 PM   #4
I have to be honest, a lot of that is way over my head. It will take several readings for me to figure it out.
Old 06-27-2011, 04:34 PM   #5
Rewards Points: 212
The whole site he linked has TONS of info though...
http://www.buildingscience.com/resou...wner_resources
The Following User Says Thank You to coderguy For This Useful Post:
DocWard (06-27-2011)
Old 06-27-2011, 04:38 PM   #6
Rewards Points: 212
I actually liked this article from the site; that helped alot..
http://www.buildingscience.com/docum...-basements.pdf
Old 06-27-2011, 11:59 PM   #7
At least some of it makes sense.
Old 06-29-2011, 11:20 PM   #8
Rewards Points: 160
I don't really know where the water problem is coming from, but iuf its due to any standing water problem, then look up "french drains"
hellothere123 is offline   Reply With Quote
Old 06-29-2011, 11:24 PM   #9
Not standing water so much as it is high water table and springs, I think.
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 11:42 AM
Adding heat to a basement, newbie questions frizbplaya HVAC 3 01-28-2011 03:57 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 03:55 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 09:49 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
