Yard Art - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 06:53 PM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Yard Art
This is a little project I've been working on, made up of pieces of flea market finds. It's built on a piece of 3/8" solid threaded rod. The bottom 12 inches of the rod slides into the green pipe (9/16 I.D.). The pipe is cemented in the ground, but there is nothing securing the threaded rod to the pipe. It would be too easy for this thing to sprout legs and walk off.
I know if anyone really wants it, they will find a way, but I want to make it just a little bit harder than to just pick it up and walk off.
So I'm looking for a way to secure the rod inside the pipe.
Any ideas?
Old 12-21-2012, 06:57 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Drill and tap the side of the pipe and use a set screw or bolt
The Following User Says Thank You to TheEplumber For This Useful Post:
Blondesense (12-21-2012)
Old 12-21-2012, 08:16 PM   #3
DIY staff
Rewards Points: 7,174
This is easier than it sounds----a tap is like a screw that cuts threads---turn it into the drilled hole using a tap handle--unscrew it and the hole is threaded like the inside of a nut---
You could use a regular screw if you wish---
Oh, And I like the sculpture!
Old 12-21-2012, 08:31 PM   #4
Plumber
Rewards Points: 452
Here's other way- looks like you can weld judging by the art piece- drill a hole in the pipe, now tack weld a nut centered over the hole. Thread a bolt through the nut as a set screw
Old 12-22-2012, 12:00 AM   #5
Stuck in the 70's
Sorry, no welding. It's on the wish list though. Those arms were taken off of a couple of broken hanging candelabras.
Thanks for the suggestions guys. Come to think of it, I think DH has a tap set somewhere. I'll give that a try
Old 12-22-2012, 12:04 AM   #6
Plumber
Rewards Points: 452
You might want to use a center punch to start the drill bit- it might want to walk off the edge of the pipe
Blondesense (12-22-2012)
Old 12-22-2012, 10:04 AM   #7
Rewards Points: 222
you don't even need to tap it. find a good sized nail, and a drill bit just a tic smaller. drill hole and hammer nail in, then grind nail flat.
Fix'n it is online now   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Blondesense (12-24-2012)
Old 12-23-2012, 05:10 AM   #8
Well that is really cool!
I'll steal it
How long does it take to get from New South Wales to Missouri
Wandererone is offline   Reply With Quote
The Following User Says Thank You to Wandererone For This Useful Post:
Old 12-23-2012, 09:11 AM   #9
Frustrated DIYer
I can't really be handy here, but I just want to tell you that I really like that project! Thanks for sharing. I hope you'll get around that slight issue you have.
Obn2012_Aus is offline   Reply With Quote
The Following User Says Thank You to Obn2012_Aus For This Useful Post:
gas pressure line in middle of yard? BlueBSH Plumbing 2 08-01-2011 01:43 PM
How to Grade Forever-Flooded Yard? TheMedicsWife Landscaping & Lawn Care 1 04-12-2010 12:46 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
