Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-11-2013, 03:28 PM   #1
old guy contractor
tcleve4911's Avatar
Wrong time for snowblower problems
I have an Ariens 828 and I lost reverse.
I engage it on the handlebar and it just wiggles forward....?
This happens in either slow reverse or slower reverse.
All forward gears work fine
Any ideas
Adjustment of some sort??
Thanks in advance
tcleve4911 is offline   Reply With Quote
Old 02-11-2013, 03:41 PM   #2
I can not find that model # on line. 828 would just mean it's 8HP and a 28 chute.
http://apache.ariens.com/images/findmodelserial2011.pdf
Old 02-11-2013, 04:13 PM   #3
Generally, there's usually a threaded rod on the shift control that is used to adjust the transmission.
djlandkpl is offline   Reply With Quote
Old 02-12-2013, 06:26 PM   #4
Could be a loose belt as well.
Jim F is offline   Reply With Quote
New Dog. Problems. Doc Holliday Off Topic 12 12-26-2011 10:59 AM
First Time Contractor Experience Problems cbj8585 Flooring 15 05-12-2009 10:48 PM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 01:09 PM
Help! A/C leaking big time IncHulk HVAC 5 03-29-2008 09:27 PM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
