Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-23-2011, 11:41 AM   #1
Wrenches needed to change blade in mitre saw?
I have a mitre that I inherited from my father and I need to change the blade. It did not come with the wrenches to change the blade and I was wondering it these are standard wrenches? (read as can I go to a big box store and say I need the wrenches to change a blade) or are they specific to the saw? Craftsman is different from Ryobi from Dewalt etc.
Thank YOU!!!
Also am I correct in assuming that the higher the tooth count the finer the cut? What blade would I use for trim? 60 or 80 tooth? Should I have a different blade for cutting 2x4's?
Evil Scotsman is offline   Reply With Quote
Old 03-23-2011, 11:57 AM   #2
Moderator
kwikfishron's Avatar
You shouldn’t need any special wrenches whether yours is standard or metric I don’t know.
Since on one day I’m cutting 2x and the next day maybe trim a 60 tooth is a good all around blade.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 03-23-2011, 12:07 PM   #3
What make and model is your miter saw? If you know that you can then call the manufacture to send you the wrenches or you can try a adjustable wrench or a ratchet and socket for the time being to remove the blade.
epson is offline   Reply With Quote
Old 03-23-2011, 12:14 PM   #4
I know it is a Craftsman but not sure of the model. (I can check tonight) I thought I remembered them being a flat (read as thin) wrench as opposed to a regular box wrench? But I couldn't swear to it?
Old 03-23-2011, 12:19 PM   #5
Yeah they are flat but if you need to remove your blade now use an adjustable wrench.
Old 03-23-2011, 12:23 PM   #6
You'll obviously need to get the quard out of the way, whatever is needed for that, but other than that, have never seen one that a standard wrench wouldn't handle. As for blades, pretty much the same guidelines that you would use for a table or circular saw. I generally keep a combination blade in mine, just so that it's ready to go if I need to cut something quick, but I have fine tooth ones for trim, etc.
Old 03-23-2011, 01:30 PM   #7
I have been using an adjustable wrench on my saw for 49 years. It was 2nd hand when I acquired it. Having wrenches supplied with power tools is a relatively new innovation.
Old 03-23-2011, 03:02 PM   #8
Thank YOU!!!
I use a 1/2" on the circular saw. The miter saws have their own wrench in the base. Just put a few open ended wrenches on it and use the one that fits. The saw should have a plunger that will lock the shaft so you only need one wrench.
Ron
Old 03-24-2011, 08:10 AM   #9
I didn't get a chance to get up to the new house last night, (that is where the saw is) but I am HOPING that it has a lock and only needs one wrench! THANK YOU ALL FOR THE INPUT! It is greatly appreciated!!!
Old 03-24-2011, 08:19 AM   #10
Average Joe/ex-Navy IC3
gregzoll's Avatar
Do not use a adjustable wrench on the nut. Use the proper size Box end wrench. The tool that comes with most miter saws are just stamped out of sheet steel and are worthless.
Old 04-01-2011, 01:00 AM   #11
Dorf dude...
shumakerscott's Avatar
I'm trying to remember if mine is left hand threads on the nut. I know my table saw is. Both are Delta. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
How to change shredder blade? mntentman Landscaping & Lawn Care 5 10-31-2010 09:31 PM
Thermostat change help needed USNRET HVAC 6 02-02-2010 07:11 PM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 10:38 AM
Mitre saw blade for 3/4 in. Oak Hardwood? bajaboy1 Flooring 3 11-29-2007 07:36 AM
