Working With Wire - Differently - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-14-2008, 03:07 PM   #1
working with wire - differently
I'm wiring a simple AC circuit for two bulbs passing through a switch.
The wiring I'm working with is non-standard for this application however. I have two 16 gauge cables (5 wires each). I was thinking of using one of those cables as hot wire, where I'd twist together ends of 3 of those wires. The other cable would act as neutral, again with 3 wires twisted at ends.
Does "splitting" the conductor wire this way (for the length of the circuit the 3 wires would run in their own insulations and be twisted only at ends) cause any issues? I'd think that would even act as increasing the gauge of the wire - making it suitable for heavier load... Am I correct or is it backwards?
electripela is offline   Reply With Quote
Old 08-14-2008, 03:16 PM   #2
Registered User
Termite's Avatar
I'd be concerned with the potential for more current through one of the wires than it can handle. Hopefully this is a science experiment and not household wiring you're doing!
Old 08-14-2008, 03:19 PM   #3
that's the thing exactly... it is household wiring and that is why I need to know if I should strip these wires down.
what is the minimum gauge needed for two bulbs, no more than 60W each?
Old 08-14-2008, 04:03 PM   #4
electripela,
why not just run 14-2? 14-2 will handle a 15a circuit. right now with just two 60watt bulbs in the circuit, u shouldnt be drawing much more than 1a, and you will have plenty of room to add more lights, outlets, etc...
i,m not an electrictian by any means, but have done some basic house wiring. im sure someone on here can answer u better, but, thats my two cents.
bob
bobo is offline   Reply With Quote
Old 08-14-2008, 05:29 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
NO! The wire gauge must be matched to the circuit amperage. BOB
Old 08-14-2008, 05:44 PM   #6
joed's Avatar
Rewards Points: 12,918
You should call an electricain. You abviuosly don't what you are doing and are going to get some one injured.
Aside from being against all codes here are some of the thing you are not considering.
What if some of the wires break and you are only left with one?
What is the insulation rating on the wire. Is it at least 300 volts like AC wiring?
What is someone else sees that cable and assumes it is low voltage door bell? Not an unusual assumption.
Old 08-14-2008, 06:10 PM   #7
buletbob,
i understand that the wire ga needs to match the amps. 14ga wire, 15a breaker, 12ga wire, 20amp breaker. why cant you put the two 60 watt bulbs in a circuit with 14ga wire? the load is not going to trip a 15a breaker, and if it shorts out, the break will trip, nothing will burn. pls advise.
bob
Old 08-14-2008, 07:19 PM   #8
buletbob's Avatar
Originally Posted by bobo View Post
buletbob,
bob
Yes you can. Most common lighting circuits are feed from 14GA 15 Amp circuit. my answer to the first poster was . you can't run multiple 18 Ga wires in a circuit and expect them to carry 15 Amps. if one of the fixtures shorted out these wires will be the first to heat up before the breaker trips.
Old 08-14-2008, 08:03 PM   #9
thank you all,
i'll just face the daunting task of replacing the existing wire.
this circuit is about 20-25 ft long. 14g wire will do then?
Old 08-14-2008, 08:09 PM   #10
buletbob,
ok, im on the same page now bob! i didnt realize, for whatever reason, that you were answering the op, sorry, i got confused! yes, i agree, the thinner 16ga wires would burn before the breaker trips, wires would be too light for the circuit.
bob
Old 08-14-2008, 09:47 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
thank you all,
That depends on the existing circuit and th breaker size. If it is a 15 amp breaker, then #14 is good. If it is a 20 amp breaker, then you must use #12.
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
I really need help! POOK Electrical 34 04-20-2007 07:01 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
