Word 7 Spacing Of Lines In Documents - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 11:25 AM   #1
word 7 spacing of lines in documents
Hi Helpers
I have a book on word 2002 my old word of course!
But now have word 2007 and my older book explains how to change the spacing between lines but it won't stay
I have to change this every time I start a new document ?
How do I formate the spacing to stay all the time ?
I have looked for the edit box but can't find one.
Robut
robut is offline   Reply With Quote
Old 03-08-2011, 05:10 PM   #2
Go to Page Layout. Click the little arrow at the bottom right of the box. Set your format and click "Set as Default" at the bottom of the panel.
amen2u is offline   Reply With Quote
Old 03-09-2011, 04:02 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Try This:
Disclaimer
& Stay Safe
.....Bob Lavery
Last edited by PaliBob; 03-09-2011 at 12:44 PM. Reason: ref Post#4, I added Layout Only Note (My Goof)
Old 03-09-2011, 08:31 AM   #4
Rewards Points: 6,652
Actually both are incorrect. It is 'Style Set' that needs to be changed, not Page Layout. Style Set change sticks, which means every time you open Word, it will be the same. Page layout only sticks for the time you have word open, and have to set again when reopening. The slipsticksolutions.com webpage has a lot of info on Microsoft Office.
The Following User Says Thank You to gregzoll For This Useful Post:
PaliBob (03-09-2011)
Old 03-09-2011, 08:49 AM   #5
Sorry, I was thinking of Word 2010. I have recently updated. In this version, once you set the format and select Default, you are asked to specify if you want to apply the formatting to only the current document, or to all documents based on the Normal template.
I have got to pay moire attention to details. Good of you to provide the correct way for his release.
Old 03-09-2011, 08:37 PM   #6
Tool Geek
PaliBob's Avatar
Originally Posted by robut View Post
....How do I formate the spacing to stay all the time ?
Try This
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-10-2011, 10:17 AM   #7
Spacing word 7
Originally Posted by PaliBob View Post
Try This
Thanks to all you who helped with this spacing problem . I have it working now
It was a bummer.
Why can't we run our country this well ?
I just love this DIY forum
Robut
Low point in water supply lines dave11 Plumbing 3 02-01-2011 08:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 11:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 06:02 AM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 08:05 PM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 06:50 AM
