Wooden Screen Door Spline - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 04:33 PM   #1
I need to replace the screen in my screen door. The door's frame is made of wood that is perhaps 1/2" thick. There's a 1/4" wide channel on the frame's interior edge into which a black rope is stapled (a million times) that serves as the spline to hold the screen material.
The only available splines I saw at Home depot are the rubber type, and the thickest is .19". They do have generic nylon braided rope, but I'm not sure if this is suitable or what size to get (does it compress? stretch? what about when wet? etc).
a) Any ideas of what is/where to get a suitable replacement spline (rubber or rope)?
b) Or can the existing rope spline be reused?
Thanks,
James
Orange, CA
chimivee is offline   Reply With Quote
Old 05-11-2010, 04:45 PM   #2
they do make diff splines and a roller tool for pushing it into the groove. with a proper fit staples are not needed, keep slight tension on the spline material as you roll it into the groove. you may need to apply a couple of temp staples across from where you are splining to get tension in the screen and hand tension on the screen during the last third
The older I get the better I was
Old 05-12-2010, 05:54 AM   #3
Measure the groove in the door, use a vinyl spline about the same size. The screen takes up part of that dimension.
Old 05-17-2010, 11:56 AM   #4
Thanks for the replies. I went to the four major hardware stores in my area - Lowes, HD, Ace, OSH - and the largest spline I found was .21" at Ace. I suppose I'll order some online. If anybody has a recommended source let me know.
And to be clear, because the channel is 1/4", I should get 1/4" spline? And the thickness of the screen itself will make the fit tight?
Thanks,
James
Orange, CA
Old 05-17-2010, 11:57 AM   #5
is there spline in it now
Old 05-17-2010, 12:10 PM   #6
Here's what I found:
http://www.acehardwareoutlet.com/pro...px?SKU=5179882
• 25' Long
• .250 (1/4")
• For aluminum & fiberglass screens
• Top quality vinyl
• Round hollow core and serrated used to hold screen material in window and screen door frames
• Black
• Bagged
I'm wondering… it says for "aluminum and fiberglass screens"… Because this is for a wooden screen door, is expansion/contraction of the frame an issue? Or is it minor enough not to be a problem? [A correction to my initial post: screen door is about 1" thick (not 1/2") with 1/4" channel.] Again, the original screen was held in with a stapled rope spline - which, after removing, I can see would be a major pain to replicate.
Old 05-17-2010, 12:15 PM   #7
Yes (well, there was - I tore it out). It was a braided rope spline, that was stapled in place with long narrow staples about every 1.5". House was built in the '50s, but I don't know how old the screen door is .
Old 05-17-2010, 12:22 PM   #8
Screen door is just like this:
Old 05-17-2010, 03:02 PM   #9
If it were me, I'd take my router and remove the lip between the opening and the spline. So that you have a recessed pocket just larger than the opening. Then I would have a screen with an aluminum frame made. I would also have a window with the same type of frame and maybe some lexan. That way I could switch them out. If it was rugged enough to support it, I'd go with glass- not sure if you can get a custom low-e one made, but that's the route I'd go if available.
Sparky8370 is offline   Reply With Quote
Old 08-16-2010, 12:54 PM   #10
Chimivee, I'm wondering how this worked out for you. I'm in the same situation with an older door and the rope spline. Thought I'd check in to see what the final result was for you before I place on online order.
Thanks.
Mudslide is offline   Reply With Quote
Tiling a patio that already has screen enclosure. gggonzalez Flooring 4 07-05-2014 10:24 AM
Screen and Recoat correct way to go? pktrocket85 Flooring 4 03-19-2011 01:49 PM
replacing screen material on storm door gquayle General DIY Discussions 2 01-25-2010 07:26 PM
Is screen measured like lumber? DIYtestdummy General DIY Discussions 4 07-20-2009 03:07 PM
Compaq Presario issues (1) chugging and (2) Compaq Organizer screen proofer PC Repairs & Upgrades 12 09-21-2008 09:36 AM
