| Chantel |
07-27-2005 08:14 AM |
Bob,
I don't know if you can buy 2 component sprayed foam in South Africa, but if you can, it would be the perfect solution. 2 component foam has a closed cell structure, which makes it impervious to water. Whilst it is used primarily as an insulator, it is also used in the building industry for retro window fitting. The product can also be sanded, plastered and painted. It is not necessary to plaster it, but one can if one wants to. Visit www.spray-insulation.co.uk for more info regarding Handi-foam sprayed foam insulation. If you can get it in South Africa, it is an excellent product.
Don't buy the single component foam because unlike the 2 component, it acts like a sponge. The single component does not have a closed cell structure.
