Wood Stove Problems - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 11:13 PM   #1
wood stove problems
I have a new clayton wood stove. I have been unable to get the blower to work with the house thermostat. If I direct wire it, it will run. I have replaced the inside thermostat and the limit control already. What else can be the problem?? Not much help with the owners manual. Anyone have a good idea what might be the problem?
countrygal101 is offline   Reply With Quote
Old 12-16-2011, 07:27 AM   #2
DIY staff
Rewards Points: 7,174
Call their customer service technical help line.
Old 12-16-2011, 07:50 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
I assume your thermostat is already connected to a regular furnace. Most thermostats will only control one device.
PoleCat is offline   Reply With Quote
Old 12-18-2011, 09:51 PM   #4
clayton 1600ef
thanks for your replys. The clayton stove has its own indoors thermostat. Today I had a friend check the wiring.. found out there is no current going from the furnace electric box to the auto damper. (The auto damper stays closed) The furnace kicks on runs for maybe 5 seconds then turns off, then maybe 5-8minutes later does the same thing. Over and over with this cycle. No change in this when the inside thermostat was raised to 80. I am beginning to wonder if the electric box is bad? I hope I get some technical help from them. The book that came with it is not helpful at all.
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 11:04 AM
HVC on with Wood Stove? fpianka HVAC 5 11-14-2010 04:22 PM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 03:48 PM
River Rock Hearth for Wood Stove Borges Remodeling 9 11-02-2008 12:39 PM
