Wood Stove Install? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 09:41 PM   #16
Rewards Points: 920
The advantage to running it through the roof is that you can use single-wall pipe up to the roof line, or ceiling in your case. So you need a thimble deal to go through the ceiling, then a brace deal at the roof and a roof flashing deal, then a storm collar and a cap. The triple wall stuff is pricey.
Another advantage is that you will get more heat off the single wall pipe.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
kevin07 (01-30-2013)
Old 02-02-2013, 09:19 PM   #17
If it is 8 inch you should be able to find someone that has some 8 inch triple wall they bought by mistake and are willing to sell. You are asking for big big trouble not at least seeking expert advice. For one you will never get an 8 inch outlet stove to work properly unless you know what you are dealing with. The day that thing back drafts and blows the door open with hot embers remember my warning. You need to get the idea of single wall being very dangerous. I would say minimum 1000 dollars for an install to code, not sure on the labor, good luck. Oh, your insurance company is not going to cover the damages this stove is most likely to do.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
Mr.Burns (02-03-2013)
Old 02-02-2013, 10:01 PM   #18
Did a bunch of research and orderd all the parts i need total was $530 Im running single wall to the celing then changing over to chimney pipe at the pipe support in the celing then sleave deal for inulation, flashing for going through the roof storm collor and cap.
paintdrying, the wood stove isnt goin to cause any damages ... mabe try to sound like a little less of a smart ass
kevin07 is offline   Reply With Quote
Old 02-03-2013, 07:41 AM   #19
Rewards Points: 3,130
Just be sure you go to a "real" woodstove store. Not someplace like Lowe's or Home Depot.
Old 02-03-2013, 07:55 AM   #20
Rewards Points: 12,844
"paintdrying, the wood stove isnt goin to cause any damages ... mabe try to sound like a little less of a smart ass"
Must be your first wood stove.
The Following 4 Users Say Thank You to joecaption For This Useful Post:
jagans (02-03-2013), Mr.Burns (02-03-2013), oh'mike (02-03-2013), paintdrying (02-03-2013)
Old 02-03-2013, 01:18 PM   #21
Concrete & Masonry
Rewards Points: 470
Why would you say that?? Do you think that a large percentage of wood stoves end up burning the the garage down or something?? I'm sure some do, but that doesn't mean there isn't a safe way to install one. Personally, I give the guy credit for doing his share of research first before installing it. If he's safe with the installation, he'll likely never have an issue..............
jomama45 is offline   Reply With Quote
Old 02-03-2013, 03:49 PM   #22
Roofmaster
Rewards Points: 2,172
Having owned several wood stoves, I have had the best luck using metalbestos pipe going through cold areas like your ceiling, attic, and roof. Single wall or double wall unlined pipe gets cold and cold air drops. You can use single wall inside, till you hit combustibles. I would also most definatley use a barometric damper if you live in a windy area, to prevent surging. Masonry chimneys that run up through the house are OK, because they stay warm, but single flue outside masonry chimneys are difficult to get to draft to get your fire going. My neighbor built one like this and he had to open the door and stuff some paper in his flue, and even then it was hit or miss. You need even metalbestos to be at least 2 inches from combustibles.
Metalbestos is expensive, but it is also very good pipe, rated to 1800 degrees if I remember correctly.
Old 02-03-2013, 04:35 PM   #23
the stove pipe brand i got was metal-fab. I have a woodstove in the house that i have not had any issues with my mother has lived with woodstove her whole life never any issues. My stove is the house is supposed to be 8 inch but its choked down to 6. He never had any problems with it and it seems to draft pretty well.
Aurora wood stove info needed. jehiatt General DIY Discussions 11 01-18-2012 09:35 AM
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 12:04 PM
HVC on with Wood Stove? fpianka HVAC 5 11-14-2010 05:22 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Painting behind wood stove donnieh1 Painting 4 11-08-2008 09:42 AM
