-   -   wood stove insert (http://www.diychatroom.com/f2/wood-stove-insert-13723/)
Karpol 11-24-2007 02:19 PM
wood stove insert
I recently moved into a cabin with a wood stove insert. The stove has two pull levers at the bottom, and a large pull lever top right. Also, has an electric fan.
The name of the stove has been painted over, so can't contact the manufacturer.
I'm not sure what the levers are for. When burning a fire, a lot of smoke comes into the house, upon opening the stove door to stoke. So, I wonder if I knew what the levers are for, and how best to adjust them, if this would help.
Any suggestions?
Thanks,
Karpol :(
skymaster 11-24-2007 04:12 PM
karpol; I dont know but here is my guess :} the top right could be the flue damper which if closed is a great reason for getting smoke into your place. Usually bottom levers are for ash removal, some stoves have an ash bin the will open or swing out. I would take a few mins when there is NO fire and cool to investigate. Also take photos of stove, more than likely it was purchased close by and if there are some dealers show em pics. most likely they can give ya a name and instructions even.:)
Karpol 11-24-2007 05:18 PM
good suggestion skymaster!
skymaster: Thanks so much for your reply. I'll do as you suggest and take a photo to local stove dealers.
I've been experimenting today, and the second fire seems to be going better.
Thanks again,
Karpol :thumbsup:
joasis 11-25-2007 05:33 AM
Ash grate shaker for one on the bottom, possible fresh air intake for the other, now which is which you will have to figure out...the damper is the top lever, and generally it is either open or closed...do not try to "choke" it with a partial opening.
skymaster 11-25-2007 10:52 AM
Joasis: THATS THE ONE I COULDNT REMEMBER THE SHAKER :laughing::thumbup:
Karpol 11-25-2007 11:56 AM
Joasis,
Thanks for the information.
It seems that smoke will come out of the chimney whether the damper knob is pushed all the way in, or pulled all the way out. I will try not to "choke" it as you suggest.
One more question...the "ash grate shaker" knob?????? I don't see any openings in the flooring of the woodstove. What is the function of this knob?
I'm used to using a very simple wood burning stove, so this one has me baffled, as pushing and pulling the levers hasn't seemed to make much difference in performance.
Thanks again,
Karpol
