Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-06-2009, 06:03 AM   #1
Wood stove grate?
can i put a grate inside my wood stove to keep the wood off the firebrick for better burning? no air gets under the logs. It is a Alaska 2500 wood burning stove.
econdave is offline   Reply With Quote
Old 01-06-2009, 03:19 PM   #2
Craftsman
Wood stove grate?
One of my houses had a buck stove insert that had a small grate in it and it worked fine it sat low to the bottom of the stove, may have been custom made or cut to fit. On cold winter days I kinda miss the extra heat but not cutting firewood!
Superrick is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
wood stove insert Karpol General Discussion 5 11-25-2007 12:56 PM
