Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-30-2005, 12:57 PM   #1
Question
wood stain
I have an unfinished door I am trying to match to 1920's woodwork.
I started with Minwax Golden Pecan, it comes out too red. I am considering changing the color to a "whitewash" look. How do I do this? Is it it impossible to change this color. I am truly novice...can you tell?
:confused:
patp is offline   Reply With Quote
Old 03-30-2005, 07:48 PM   #2
Contractor
wood stain
What would you like to do? Match or whitewash? Was the MinWax varnish or stain?
Teetorbilt is offline   Reply With Quote
Old 03-31-2005, 11:23 AM   #3
Red face
wood stain
Thanks for the reply. The Minwax is a stain. I would like to "remove" or lighten the stain (remember I said it was too red) and then add the whitewash. I guess I need to know if I really need to remove the red stain or if I can just add the whitewash and the whitewash will deaden the red? Want to get the door to the original unfinished color. Make sense?
Thanks,
patp
Old 03-31-2005, 04:29 PM   #4
Contractor
wood stain
The only way that I know of to get back to the original color is to sand until you hit unstained wood.
You can bleach the stain to lighten it.
The whitewash will lighten it up some, you can apply multiple coats. This will not match the original woodwork.
If it were me, I would bleach the door, find some scraps of the same wood and stain and bleach them. Now every thing should be the same color and you know what you don't want. Go to the store and buy some of those ittty-bitty cans that you think might be close to what you are trying to match and put it in a small area of your sample board. BTW, this is where you should have started before putting anything on the door. If you get close, you can mix the stains to get closer. If you play with this for a while, eventually you will get a perfect match.
Another thought is that you might just be looking at old varnish. Most oil based varnishes have some color to them and they darken with age. You can 'antique' varnish by adding a little stain to it. Do not try and mix waterbased stain and oil based varnish, it won't work.
All of the above applies to oilbased products. I have tried waterbased varnishes a few times and simply don't like them.
Old 03-31-2005, 08:13 PM   #5
Smile
wood stain
Thanks, the answer is what I suspected, but did not want to hear. This is an inexpensive door, and may just start over. Thanks for the very thorough answer.
patp
painting over a wood stain franko24 Painting 5 10-13-2010 08:52 PM
how soon can I stain PT wood? falcon802 Carpentry 5 06-29-2006 06:15 PM
Help wood stain showing through paint laviticus Painting 6 03-18-2006 12:35 AM
wood stain farrington135 Painting 3 08-26-2005 09:38 PM
