Wood Front Door Care - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2009, 12:30 PM   #1
I have a nice 3 yr old wood front door. I'd like to know how I should care for it? What do I use to clean it? How often should I clean it? Should I seal it and protect it and if so with what and how often? I just want to make sure I keep it in perfect condition and don't have to refinish it in 5 yrs. It is protected by a covered porch so does not get direct sunlight. There is no storm door.
jeffro49 is offline   Reply With Quote
Old 01-19-2009, 01:38 PM   #2
Registered User
Termite's Avatar
Do you know what the original finish on the door is? Is it an oil, a stain, and does it have polyurethane (clear gloss) on it? What wood is the door made of?
Old 01-19-2009, 02:22 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
By having it protected for the sun you made keeping your wood door nice much easier you will probably get by with just cleaning it once in a while
Tom Struble is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
wood front porch steps dlhein Carpentry 4 05-11-2008 08:06 PM
