Wood Fireplace Insert Temperature - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 09:24 AM   #1
Wood fireplace insert temperature
I have just purchased a Jotul C350 fireplace insert.
They gave me a temperature thermometer, which was placed just above the door. They told to break in the insert at certain temperature- 200, 300 and 400 degrees. I am having trouble getting it above 200.
I am for the most part burring maple. Outside temperature is between 10- 20 degrees.
Any suggestions?
homewood is offline   Reply With Quote
Old 01-04-2010, 09:59 AM   #2
Rewards Points: 5,336
Any suggestions?
Try burning oak. I would also check to see if the thermometer is working correctly.
Ron
Old 01-04-2010, 10:04 AM   #3
the Musigician
DangerMouse's Avatar
we burn maple, oak, cherry, walnut, etc.... hickory burns REAL nice and hot ...
but, whatever you're burning, as long as it's dry, you should be getting better than that.
is it in the right spot? as per instructions?
have you tried emailing Jotul?
DM
Tags
wood fireplace insert
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Fireplace Insert mcblackburn@nc.rr.com General DIY Discussions 6 11-19-2008 09:33 AM
Fireplace Insert? dpreznik HVAC 4 04-18-2008 06:11 PM
Wood Insert flyultralite HVAC 1 11-22-2007 05:29 AM
Wood Stove Insert Problems JAVAMAN General DIY Discussions 3 11-14-2007 06:57 PM
