Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-09-2010, 06:00 PM   #1
wood finishing
Beginner needs help! I am out of polycrylic wood finish and would like to apply one more sealer coat to my stained piece. I have plenty of polyurethane. Can I use this oil based product on top of two coats of the water based finish? Any do's or don'ts on this? Thanks
blisswoodworker is offline   Reply With Quote
Old 02-12-2010, 10:21 AM   #2
remodeling pro
wood finishing
Technically you can apply the polyurethane over the waterborne product, but I would suggest just getting some more of the same product for the last coat. I have never been a fan of mixing products.
troubleseeker is offline   Reply With Quote
Old 02-12-2010, 01:25 PM   #3
sdsester's Avatar
wood finishing
Ditto. It is not worth having your top layer compromised after all the other work. Stick with fully compatible chemistries for best results.
sdsester is online now   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Wood Floor Finishing Question: minneapolis1 Flooring 3 09-30-2008 08:12 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
