Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-02-2009, 04:22 PM   #1
wood fence - Questions
I'm building a small wood fence today. What kind of screws do I need to buy and how long should they be?
I probably shouldn't ask two separate questions in one post, but they both pertain to the same fence.
The fence I'm building is about 20' long and I want to put it about 12" from the foundation of the house, in the back yard.
Before I start digging, how can I tell where the pipe leading to the septic tank is? How far down would it be?
As far as the utilities go, the gas, water and electric meters are all on the sides or front of the house, as well as the phone box. So it should be fine to dig the post holes. Is there anything else I'm not thinking of?
Permit? Would I need one for something that's just decorative?
gma2rjc is offline   Reply With Quote
Old 05-05-2009, 02:43 PM   #2
HandyMan Engineer
Most areas have a locate company that is linked with utility companies. Up here it's Call Before You Dig. Here the service is even free. Even if you're hand digging it can save you some head ache by avoiding an interference. As for the fence, we kind of need to know what your building this out of. Size/thickness of boards. Pressure treated/Cedar or whatever. Size type of posts height of fence?
These would help.
sendres is offline   Reply With Quote
Old 05-05-2009, 03:37 PM   #3
I'm pretty sure the only thing in the ground in that area is the pipe leading to the septic tank. But it would be a good idea to double check. I believe it's called Miss Dig here, I'll call them first. Better safe than sorry.
The fence will be just under 4' tall. I believe the posts should go in the ground about 4' down. I'll find that out when I call to ask if I need a permit.
The boards are the individual dog-eared fence pickets they sell at Home Depot. I got them free from Craig's list. I don't really know if they're PT or not. The wood is very light in color like untreated wood, but there are a few streaks of green going through some of them. They are 1" x 6" Pine. I'll be using 4" x 4" PT posts and 2" x 4" boards to attach the pickets to.
I hope that all makes sense. Thanks for your help.
Old 05-05-2009, 03:54 PM   #4
47_47's Avatar
Normally, screw or nail length should be 3x the material you are fastening through. 1x pickets 2-2½" fasteners. I'd use either hot dipped galvanized, exterior deck screws or stainless.
Paint or seal the bottom of the pickets and rails prior to installing. You can put them up wet if stick building.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 06:43 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 07:03 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 10:21 AM
