Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-28-2007, 04:55 PM   #1
wood counter stain...what is it?
Hi
I just had a butcherblock counter installed and after stalling for a couple of weeks decided to sand and seal it. There has been what I thought was a water stain around most of the sink so I sanded last night and made it go away but as of this morning, it's back . I'm attaching a picture and you can see where I was sanding and where the stain is again.
It's not wet, the sink wasn't even used so I am wondering if it could be what ever was used to reinstall the sink. I have no idea what that would be as the guys that did it were left to it and all they said was not to pull any gooey stuff thinking it was dirt so I assumed they used some sort of silicone. Meanwhile nothing has oozed out from the sink as they did a pretty neat job.
Anyway, now I am wondering what will happen when I finish sanding and want to seal. I am using a food safe wood oil. I was also considering staining it dark before sealing but not knowing if that area will take is making me nervous about that (what if that stain is some sort of oil or non water substance?).
Does anyone have any thoughts on what I am dealing with here and whether I should ignore it and continue or is there something I need to do?
Jean
Dusty is offline   Reply With Quote
Old 10-28-2007, 05:23 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
I wouldn't stain a food prep area
The oil you use to "seal" it may not tolerate it well
(but that could depend on what you are using to "seal" it)
The stain...I'd think it was leaching from whatever 'caulk' they used under the sink (sink to counter)
I thought they weren't to use any on this type of app. (raw wood) but it's not my specialty I could be off on that
slickshift is offline   Reply With Quote
Old 10-28-2007, 10:23 PM   #3
remodeling pro
If it was silicone, it would not be leaching like that. Looks like it might have been bedded with plumbers putty, and what you are seeeing is the oil leaching into the wood. You are right in your concern about solving the problem before sealing the top, as the oil is going to pose a problem. Unfortunately, I think you will have to remove the sink, remove all the old putty, clean the wood to remove the oils and reset the sink.I would finsih the top before resetting the sink, as it will be easier to clean any squeeze out off of the sealer wood, rather than the raw wood, plus you can completely seal the edges of the cutout for moisture.
troubleseeker is offline   Reply With Quote
Old 10-29-2007, 03:10 AM   #4
Oh argh......that was the answer I was afraid of. Hopefully it won't be me removing the sink and replacing it as I'll be calling the guy who did the install to see if he will fix it (since he did it).
Meanwhile if I don't stain (I was going to use coffee so no biggie with food safety) and just used the wood oil (which was made for butcher blocks) would the leached oil be a big deal? Just thinking, oil with oil might be okay. And if it is oil, that is better than water as far as the wood goes isn't it?...or am I tilting at windmills?
Jean
Old 10-29-2007, 10:10 PM   #5
remodeling pro
Jean
My guess is that there would not be a problem if you just go with the oiled finish, as they would just meld together as you suggest.
Old 10-30-2007, 09:33 PM   #6
slickshift's Avatar
Ummm...I would assume there is a big difference between plumber's putty oil and mineral oil, just as there is a difference between lemon oil, peanut oil, linseed oil, alkyd oil, and 3 in 1 oil
You want to find out exactly what the stain is, and exactly what you are "sealing" this counter with, and their compatibility with each other (and with coffee oils) before continuing
Old 10-30-2007, 09:49 PM   #7
Does that mean I have to do something sensible like a sample piece? I could easily do that if I had any plumber's putty, but I don't. More and more it's looking like the installer needs a phone call to find out what he used and if he can give me some of it or come and make it go away somehow.
Old 10-30-2007, 10:43 PM   #8
Unless this sink is a prop in a movie, the wood will turn in a short period of time. You NEVER put wood in proximity to water, NEVER.
Ron
Old 10-31-2007, 03:22 AM   #9
Gee wood is around water all the time (boats come to mind) and butcher block counters are pretty standard. They just need the protection of something like an oil to prevent water penetrating. In this situation, the ideal would have been to have that counter sealed before the sink was installed, but no such luck, and in the research I did before deciding to go this route, no one ever had a problem doing it after My issue is I have never seen this particular problem I am having being mentioned so it must have something to do with what they used when they installed that sink.
Old 11-02-2007, 01:52 AM   #10
You used tongue and grove hardwood flooring....right?? My brother has installed hardwood like this before for people. If you take a wet rag and wipe it with water it will give you the same look as the oil based finish that you will be applying. In otherwords, If you wet a piece of wood...this is the look of the hardwood after it is finished' I wouldn't worry about it. I am not sure of the best finish though.
localtradesman is offline   Reply With Quote
Old 11-02-2007, 04:23 AM   #11
Nope, it's not T&G. It's butcher block, oodles of pieces of oak (in my case) that have been sandwiched/glued together (for lack of a better word) into one solid piece of wood about 1.5" thick. Here's a link in case you'd like to see what they are like butcherblockspecialist.com/Countertops.htm
Old 11-03-2007, 02:01 AM   #12
There are a few butcher block finishes available.
Raw almond oil, mineral oil and or beeswax can be combined.
Other oil finishes may invite molds.
Try www.woodfinishsupply.com
RemodelMan is offline   Reply With Quote
Old 11-03-2007, 06:19 PM   #13
Thanks for the info and the site.
Old 11-07-2007, 01:53 PM   #14
Jean
I was wondering how your project turned out. I have also installed oak butcher block in my kitchen. I would like to stain it a dark brown and then seal with a food safe sealer. Did you end up using coffee as a stain?
Ally
Ally is offline   Reply With Quote
Old 11-07-2007, 04:52 PM   #15
To be honest I haven't actually finished it yet. I had to find my sander which took a few days but that's another story.
Meanwhile I did do a test of the oil next to the stain and it should match enough that only I will know it's a stain.
On a test piece I did try some darker stains. The coffee wasn't substantially darker than normal even when oiled so not really worth the effort. I also tried a walnut stain and it did go darker but would take a few coats to go a lot darker. The wood oil itself darkens the wood quite a bit.
If you go to ikeafans.com there are some pictures of tests one person did trying various stains on butcherblock. I think to get a deep stain you'd have to do quite a few coats or something. As well if you google natural stains you can come up with other food safe things like tea or various plants which are supposed to darken wood. The other thing that will really make oak dark is ammonia. I haven't tried it yet but I thought I'd pour a bit on and see. Usually furniture gets tented for ammonia but that's a bigger deal than I want to get into.
Wood Counter Tops billinak Remodeling 16 12-19-2012 03:18 PM
painting over a wood stain franko24 Painting 5 10-13-2010 08:52 PM
how soon can I stain PT wood? falcon802 Carpentry 5 06-29-2006 06:15 PM
Help wood stain showing through paint laviticus Painting 6 03-18-2006 12:35 AM
wood stain farrington135 Painting 3 08-26-2005 09:38 PM
