Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-19-2012, 09:58 PM   #1
NicoleLM88's Avatar
Wood burning stove
Is there a safe way to vent a stove out a window?
NicoleLM88 is offline   Reply With Quote
Old 09-19-2012, 10:41 PM   #2
Wood burning stove
Just not going to happen.
It would have to go out the window then up so it was above the roof line, how would you support all that pipe doing it that way?
Old 09-20-2012, 05:44 AM   #3
Master General ReEngineer
Bondo's Avatar
Wood burning stove
Nope,... You need a proper Chimney for a woodstove...
Old 09-20-2012, 09:19 PM   #4
Wood burning stove
i am thinking of doing just that. basically i would be using an existing window opening to run the chimney out of the basement. then a small slab to support it, running up the side of the house.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Installing a wood burning stove. rickjames8 Building & Construction 13 10-30-2012 11:02 PM
Tiling Over Painted Wood Paneling for Wood Stove Insert MegMarkR1 Tiling, ceramics, marble 2 02-07-2012 12:45 PM
Wood Stove Old Masonry Chimney markx Building & Construction 5 11-18-2011 10:57 PM
insulated wood burning stove pipe dellison7 General Discussion 5 03-14-2011 01:48 PM
Fire Place / Wood Burning Stove Question fburke Building & Construction 1 12-27-2007 10:52 AM
