Wood Boiler Set Up - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 08:27 PM   #1
wood boiler set up
Hello I am currently putting in a indoor wood boiler. It will be used with a Hot air furnace. I currently have everthing plumbed with no problems. I have a heat exchanger that is in the ductwork. My question is how do I get the fan of my Bryant plus 90 gas furnace to come on & off with a separate thermostat? Can I just wire the second thermostat to the G & R terminals? I want the gas furnace to still take over the heating requirments if the fire goes out.
Thanks,
Scott
sruchar is offline   Reply With Quote
Old 09-26-2009, 06:12 AM   #2
DIY staff
Rewards Points: 7,174
Hi SRUCHAR!!
I hope some one jumps on this for you,can't be to difficult.
My reason for posting is to ask you how you will keep the boiler from freezing up when it is not being used.
I'm thinking of doing something similar ,however I have hot water heat --Whole system would need antifreeze.
Come on hvac guys.WAKE UP-WAKE UP.HA HA HA
Old 09-26-2009, 06:15 AM   #3
DIY staff
DUH--I just re read your post,You said "indoor" My foggy mind saw"out door"
I think I'll go get some more coffee-------------------------------------------
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
circulating pump install for wood fired outside boiler tiltd General DIY Discussions 2 08-27-2009 11:45 AM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
