Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-29-2009, 02:08 PM   #1
Is it wise to tuck point with an angle grinder?
I have some brick on my home that I need to tuck point and I'm thinking of using an angle grinder with a masonry wheel to do it. Does this work well? I've seen the bosch tuck point grinder but it's like $300. I'm just a DIYer so I don't want to spend that much money. What do you guys think? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 12-29-2009, 02:22 PM   #2
nap
You talking to me?
nap's Avatar
I have seen it done with one. Just don't use too wide of a wheel.
the only real difference with the Bosch tool is you can set the depth.
Be sure to use a proper respirator.
Old 12-29-2009, 02:23 PM   #3
Ok thanks nap. If I get a 4 1/2" grinder and attach a 4" diamond masonry blade to it, will that work?
Old 12-29-2009, 04:32 PM   #4
That size is good for the vertical runs. You'll just need to clean out the ends with a chisel or a drill bit. The horizontal runs will be a little slow, but you'll have more control with the 4" unit then the 7" one.
Ron
Old 12-30-2009, 01:57 AM   #5
Dorf dude...
shumakerscott's Avatar
Get a grinder that is variable speed. Mine is a Makita. The ability to slow it down will open up lots of other uses, you don't always need the thing screaming at 12,000 rpm. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 12-30-2009, 07:54 AM   #6
gravity always wins
I've done exactly what you describe with the angle grinder. I'd recommend that you do the verticals first. The angle grinder will leave you with a half moon cut. You'll need to clean the corners out with a narrow chisel. Then do the horizontals. Otherwise you run the risk of knocking the corners off of the bricks when you chisel out the little triangles of mortar. You need a steady hand. That diamond wheel will eat brick just as easily as mortar.
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
4" Angle Grinder trout_baller Tools 9 08-11-2007 09:47 PM
