-   -   Is it wise to tuck point with an angle grinder? (http://www.diychatroom.com/f2/wise-tuck-point-angle-grinder-60544/)
jpearson311 12-29-2009 01:08 PM
I have some brick on my home that I need to tuck point and I'm thinking of using an angle grinder with a masonry wheel to do it. Does this work well? I've seen the bosch tuck point grinder but it's like $300. I'm just a DIYer so I don't want to spend that much money. What do you guys think? Thanks!
Jesse
nap 12-29-2009 01:22 PM
I have seen it done with one. Just don't use too wide of a wheel.
the only real difference with the Bosch tool is you can set the depth.
Be sure to use a proper respirator.
jpearson311 12-29-2009 01:23 PM
Ok thanks nap. If I get a 4 1/2" grinder and attach a 4" diamond masonry blade to it, will that work?
Ron6519 12-29-2009 03:32 PM
That size is good for the vertical runs. You'll just need to clean out the ends with a chisel or a drill bit. The horizontal runs will be a little slow, but you'll have more control with the 4" unit then the 7" one.
Ron
shumakerscott 12-30-2009 12:57 AM
Grinder
Get a grinder that is variable speed. Mine is a Makita. The ability to slow it down will open up lots of other uses, you don't always need the thing screaming at 12,000 rpm. dorf dude...
Maintenance 6 12-30-2009 06:54 AM
I've done exactly what you describe with the angle grinder. I'd recommend that you do the verticals first. The angle grinder will leave you with a half moon cut. You'll need to clean the corners out with a narrow chisel. Then do the horizontals. Otherwise you run the risk of knocking the corners off of the bricks when you chisel out the little triangles of mortar. You need a steady hand. That diamond wheel will eat brick just as easily as mortar.
