Wiring For Surround Sound? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-20-2006, 07:43 AM   #1
wiring for surround sound?
hi, i am going to be wiring my living room for surround sound and wanted to get some ideas. i have an lcd tv that is mounted to my wall and i also mounted my surround sound speakers to the wall. as it is now, i have routed the wires for the tv and components through the wall to hide them but the wires for the speakers are still exposed.
i was wondering what would be the best way to hide these wires. i could fish them throught the wall and have them all come out at the reciever location but is that the best way? the room is 35'x19' and speakers will be placed on both sides of the room.
starnz is offline   Reply With Quote
Old 12-20-2006, 06:22 PM   #2
not a total Newbie
The speaker wires in my system run through the floor, down into the basement, and back up through the floor. I was lucky in that the RL and RR speakers were above a closet and the main return wall for my HVAC, so the wires go directly into the wall behind the speakers.
I think they also make "flat" speaker wire that ends up looking like tape, that I believe can be painted.
Good luck!
space_coyote is offline   Reply With Quote
Old 12-20-2006, 08:13 PM   #3
remodeling pro
The "best" way to hide them is however you can. If you can fish them through the walls, that is great. We have ran them in channels cut into the sheetrock after removing baseboards, ran them behind crown moulding, drilled through the floor and ran them through crawl spaces or first story garages, then back up through the floor, ran them up the wall into an attic then back down the wall, etc..whatever works in your situation.
troubleseeker is offline   Reply With Quote
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
