Wiring Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 10:38 AM   #1
Wiring Question
i want to add a new switch to existing switch for a outside light above
my door. the way its wired is it shows two wires to the existing switch for the light in the hall, how can i tap into this using a switch for the
light outside. the wires used are a nobe and tube system.
VGI0696 is offline   Reply With Quote
Old 02-04-2008, 10:49 AM   #2
my door. the way its wired is two wires (nobe and tube) to the existing switch for the light in the hall how can i tap into this using a switch for the
light outside.
Old 02-04-2008, 12:44 PM   #3
Old 02-04-2008, 01:28 PM   #4
I blame ProWallGuy
Rewards Points: 150
ECHO ECHo ECho Echo echo.
Double A is offline   Reply With Quote
Old 02-04-2008, 02:15 PM   #5
Rewards Points: 1,274
You can't. With 2 wires at the switch, you have a hot and a switchleg.
LawnGuyLandSparky is offline   Reply With Quote
Question on generator wiring mdalli Electrical 35 10-05-2011 07:45 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 03:52 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 05:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
