Originally Posted by dikndee
Oh, I think now I understand what you are saying. There has to be a control box in front of the pump to turn it off and on. The pump was disconnected when the mobile home was moved. I will have to get a control box to connect it properly. It all makes sense now. The yellow wires will connct thru the control box with the other wires from the breaker will supply power to it. Thanks
Thats the question, is the pump a TWO wire or a THREE wire? First question I ask when wiring a pump, and usually a pressure switch is what turns the pump on, here is your other problem, you need to know the size of that PUMP in the well.
