Wire Shelf - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 06:43 PM   #1
Wire Shelf
I've got a white wire shelf in my laundry room and need something like this to join two upright poles together. The one in the picture no longer works as the poles themselves have grooves and the clamp cannot keep them up.
JKS34 is offline   Reply With Quote
Old 01-24-2013, 07:08 PM   #2
joed's Avatar
Rewards Points: 12,908
Change the poles instead of the clamp. That looks like a conduit coupler. Perhaps a piece of conduit can be used as the pole.
Old 01-24-2013, 07:16 PM   #3
I live in an apartment so I can't really replace anything. Just need something to work.
Old 01-24-2013, 09:21 PM   #4
joed's Avatar
Post a picture of the pole setup.
Old 01-24-2013, 09:30 PM   #5
Rewards Points: 13,740
Sure does look like an EMT coupling with some paint on it.
http://www.bing.com/images/search?q=...lectedIndex=24
Old 01-26-2013, 01:12 PM   #6
Dave Sal's Avatar
Rewards Points: 668
Not sure if I understand the problem, but are you saying that the poles have a groove and the connector no longer holds it tight? If so, have you considered changing the screws to ones that are a bit longer so you can tighten them a bit more?
Dave Sal is offline   Reply With Quote
Use red and black wire as 110 in Canada mattm Electrical 10 11-26-2012 07:40 PM
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
