Wire Closet Shelf Coming Out Of Wall... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 08:57 PM   #1
Wire closet shelf coming out of wall...
Hi! The wire closet shelf in my coat closet is starting to come out of the wall. The rest of the places that it is screwed into the wall are fine, it's just this one part. I have no idea how I can fix it because the peice that the screw was screwed into made a bigger hole in the wall then most screws would make. I don't know what the thing is called that the screw is screwed into. It looks like it's made out of plastic and it is kind of cone shaped. So if any one has any idea what I'm talking about and how I can maybe fix the problem please let me know.
Thanks,
Cats
P.S. Sorry if I wasn't specific enough or left something out, I'm very new at owning a home so I'm not used to a lot of stuff and am just learning.
Iluv4cats is offline   Reply With Quote
Old 01-11-2009, 10:31 PM   #2
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Does the plastic thing look kind of like this:
That is called a screw anchor (atleast thats what they are called around here.)
If so, you might beable to bring it to the local hardware store and explain whats happening to the person there and they should beable to give you one which is alittle bigger or a different (like the one in figure A) kind that should work for you and a new screw.
_
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 01-12-2009, 05:23 AM   #3
iMisspell,
Hi! Thanks so much for responding. Yes the plastic thingie is what you suspected. It's so hard to do a search for something when you only know what it looks like. Thanks so much for the information and the detailed pictures. I will be visiting a hardware store soon to see if I can fix this problem before a big hole is riped in the wall.
Thanks again,
Cats
Old 01-12-2009, 11:24 PM   #4
Rewards Points: 562
you might want to explore a bit,,,and see if you can find another stud to screw direct into. a stud sensor or the good old tap method?? Direct into studs will hold ten times as much as ANY wall anchor.
4just1don is offline   Reply With Quote
Old 01-13-2009, 06:15 AM   #5
4just1don,
The problem with this shelf is that it has at least 4 other places that it is screwed into the wall. I don't think this shelf is made in such a way that you can control where the screws go into the wall. I am trying to avoid having to redo the whole thing, or worse having to buy a completly different shelf. I should have said in the begining that this same shelf is what our coats hang from. Do you think it's still possible to change where the screws go into the wall? The one place that is coming out is one of the front supports. I wish I had a picture I could show everyone. Maybe I could take a picture of it and upload it here so it will be easier to describe what is going on.
Thanks,
Cats
Old 01-13-2009, 09:09 AM   #6
bradnailer's Avatar
One way to solve the problem is to take the shelf totally down, screw a 1*4 into the wall at the studs then screw the shelf back into the 1*4. It won't go anywhere then and with a little paint on the 1*4, you'll never notice it.
bradnailer is offline   Reply With Quote
Old 01-13-2009, 10:33 AM   #7
Rewards Points: 562
I understand what your saying. There are probably wire loops built right into the shelf. Thats not to say you can NOT hang another bracket,,a small one,,,where the studs ARE. any hardware store has alot of variety of them,,,and most 'junk' drawers do too. there is ALOT of weight on hollow wall anchors to ask to hold. You get a rod full of coats,,,its heavy,,plus whatever is on top of that. Add to that a few younger people in the house that 'PULL' their coats off hangers etc. . One 'could' make something very easy in a few minutes that would work and look decent,once painted wall color. Anything solid,bent in a slight 'u' or 'w' shape that fits the wire with a screw hole drilled in it,,,good to go!! put one on 'every' stud you can find.
Old 01-13-2009, 11:47 AM   #8
You'll have to explain to me what 1*4 means.
4just1don,
You said another bracket. When I go to the hardware store can you tell me what I would say to the person I ask to help me? I think if I just say a bracket then they will look at me like that isn't enough information. Better yet maybe I should take the whole shelf thing with me when I go to the hardware store. What do you think?
Old 01-13-2009, 12:48 PM   #9
bradnailer's Avatar
A 1*4 is a piece of wood, actually 3/4" thick and 3-1/2" wide and can come in lengths from 6', 8', 10' and beyond. You can pick one up at a lumber yard or home center. Find and mark the studs in the wall then screw the 1*4 to the wall at the studs. Then you can screw your wire shelf to the 1*4 just using screws, no anchors.
Old 01-13-2009, 12:53 PM   #10
Rewards Points: 562
seems like SUCH a mess to take the whole shelf out. Find something to closely resemble the size of wire you have to encircle,,or at least hold up,,,and use that as a explanation of what your doing. Just say your trying to screw mounting brackets from this wire basket/clothes rod to the studs ,,and the wire is 'this' big,,,holding up something of similiar size.,,,in thickness. or something standard,like pencil lead,wood part of lead pencil,,,drinking straw,,a screw,,,anything like that!!(how about a drill bit out of a small assortment that 'looks' same size!!!)
A 'bracket' takes care of a wide array of descriptions.
Old 01-13-2009, 01:04 PM   #11
Thanks everyone who replied. I feel like I learned a lot just with this one thread. I have been told I could hire a handyman to do things like this, but I think that the more I can do myself then the more I will learn about keeping my house running and the more money I will save. Thanks for being patient with me and helping me understand all of this "stuff".
Thanks again,
Cats
P.S. I will explore the suggestions given and let you guys know later what I ended up doing. Unless you don't want me to.
To:iMisspell that is a disturbing picture you have there.
Old 01-13-2009, 02:49 PM   #12
Rewards Points: 344
The big box stores sell the white, U-shaped clips:
http://www.homedepot.com/webapp/wcs/...ctId=100191188
Find the Studs and put one of these at each stud location. They mount vertically over the wire shelf. Depending on the type of wall, (drywall or plaster) you may need longer screws. You don't need the inserts if you find the studs.
Studs are 16 inches apart - or buy a "stud finder" (insert joke here)
tribe_fan is online now   Reply With Quote
Old 01-13-2009, 03:23 PM   #13
bradnailer's Avatar
Can't use a stud finder. It keeps going off in my hand. hardy har har
how's that?
Old 01-13-2009, 03:44 PM   #14
my two cents, I like Bradnailer's idea the best, those closet shelves and racks can be a nightmare, of course that is after we put all that weight onto them. Something else to consider, put an eyebolt into a ceiling joist, and use rope to take some weight off the shelve, not pretty maybe, but its a closet.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-14-2009, 11:47 PM   #15
iMisspell's Avatar
Rewards Points: 150
I too would agree with the 1x4 wooden strip.
Fastened horizontally across the closet into two studs at what ever height your current screws are at. Then just use normal wood screws to attach your shelf to the 1x4 wooden strip. It would be alittle work if you've never done it before, but for the long run would hold up the best... alittle paint, like suggested and it would look good too.
Thanks... i think
Don't know the artist, found it online long ago.
Good luck.
_
adjustable wall shelf rail amakarevic Building & Construction 1 10-31-2008 11:23 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Bury Low Voltage Wire in Wall? Tool Junkie Electrical 3 06-16-2008 07:38 AM
Paint coming off wall when I pull masking down smythe01 Painting 10 01-25-2008 01:51 PM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
