Windows Not Locking - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-29-2007, 09:04 AM   #1
Windows not locking
Good morning.
I was doing some cleaning around the house the other day and noticed that the 2 front windows of my home do not lock . They are ground level so this is a big problem, in my opinion.
A couple of things:
1) the house was a spec house that we bought 2 1/2 years ago.
2) some of the work seems to be kind of shoddy--actually reported them already to the Better Business Bureau for water problems.
3) when we did the walk through a long time ago, we actually did not check each window to make sure that it locked (our fault).
4) when I slide the lock over the window, I can still open the window very easily--or without any tension.
My question is--is there a homemade way to lock the windows with a screw or nail? I have also have seen some water marks inside the window (around the window frame) maybe from water blowing in from the outside?
Thanks in advance.
loomis1228 is offline   Reply With Quote
Old 10-29-2007, 04:31 PM   #2
Check out your warranty on the windows first thing. You should be covered by the manufacturer. If they are sliding well then it sounds like a problem with the lock itself.
Amber is offline   Reply With Quote
terrible windows mt232 General DIY Discussions 10 12-28-2008 06:37 AM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
