Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-03-2007, 12:50 PM   #1
Window Well Installation
Happy Easter!
I would appreciate some instruction on the installation of basement window wells. I am familiar with the basic process but would like adivice regarding such things as: how deep to dig below window sill, how thick should the gravel be, how high above the window sill should the well extend (what size should I buy), if I decide to sink a pipe to the footer drains, what size pipe and how do I terminate it at the top, etc, etc, etc. This is for a standard 16" x 32" window (new construction, Northeast Ohio). The grade is presently right up to the sill, but needs to go higher which is why the well. Any info, drawings or pics would be great.
Bill46 is offline   Reply With Quote
Old 04-03-2007, 05:49 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Bill46 View Post
Happy Easter!
Hi,
Here are two links to help get you started:
http://www.creativehomeowner.com/ind...ectid=chwin123
http://www.improvenet.com/Homeowner/...nt_window.html
(This link covers the window install, but there is also info. about setting the window well too)
- Build Well -
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
window installation - nails or screws mt232 Building & Construction 2 04-07-2007 08:41 AM
Double pane window installation asuka Carpentry 1 02-06-2007 03:42 AM
