Window Upgrade Payback? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-21-2010, 12:51 PM   #1
Rewards Points: 502
window upgrade payback?
I picked up an old house with what are probably 50yo+ original wooden windows, with clip in place storm windows.
what I'm wondering is how much I'd gain in insulation value with modern windows, or would I be better off just putting up the plastic on the inside in the winter, and put my money elsewear.
forresth is offline   Reply With Quote
Old 08-21-2010, 12:56 PM   #2
Depends upon the windows, if they are sealed properly
If there is insulation in the side pockets.....or if there are weights /ropes
By installing new windows & doors my heating bill dropped quite a bit
Plus the house is warmer...less drafts...and less noise
My house is from the 50's
It had replacement windows installed
...but they did not insulate the pockets
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Tom Struble (08-25-2010)
Old 08-21-2010, 03:57 PM   #3
Rewards Points: 76
I think that Dave hit it on the head. A thermal image would most likely reveal heat loss around the window as well, so simply "replacing the windows is only part of the solution. Removing the old windows, properly insulating the cavity, and then installing new windows is a more comprehensive approach.
Old 08-21-2010, 05:41 PM   #4
Rewards Points: 410
A modern window will have a R3.5 or better. ( U factor is the inverse of R )
Your lucky to have a R1 , even with plastic ( I used to use clay rope ) .
Now R3.5 doesn't sound like much but its a world of difference from a R1
especially where you live.
Comfort is worth a lot while its paying for itself also.
If I was a "yooper" year round I'd be doing every trick in the book I could
afford.
If it was a seasonal cabin with free wood for heat in an area that you'd
never get your money back if you sold it, different story.
High Gear is offline   Reply With Quote
Old 08-21-2010, 05:49 PM   #5
Just remembered
There is a 30% Tex credit up to $1500 thru the end of the year
If you spend $5000 on windows /energy improvements you get 30% back up to $1500 on your taxes
In order to meet the energy guidelines it was an extra $10 per window
Old 08-21-2010, 10:28 PM   #6
Rewards Points: 502
is the tax credit only throught the end of the year?
Old 08-21-2010, 11:32 PM   #7
Yes it expires Dec 31st
They may put a new Tax credit thru
But I haven't heard of a new one yet
Old 08-21-2010, 11:43 PM   #8
Registered User
Rewards Points: 5,466
With the storms you have an R-2. To max out at R-4 would be a considerable investment. Windows account for 25% of heat loss, even less if an older house with smaller, fewer windows than today’s floor plans (typical). http://www.explainthatstuff.com/heatinsulation.html
http://www.coloradoenergy.org/procor...f/r-values.htm
I would have an energy audit to find the best “bang for the buck”.
Think about it carefully: http://docs.google.com/viewer?a=v&q=...HiKsil4S_D_jgQ
How’s the attic insulation for your local area? Loose 35% there.
Pull a receptacle cover plate to see the type of wall insulation----- 25% there. Those two at 60% percent may equal close to the new window up-grade cost to only gain R-2 without the in/out side storms.
Air seal the attic before new insulation to prevent ice dams and heat loss. http://www.rd.com/how-to-seal-attic-...icle18158.html
You may have a balance of money left to install a thermal break on the studs, after furring them out for more insulation, if a DIY. Another option is to blow cellulose in the attic and existing walls: http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
Be safe, Gary
Old 08-22-2010, 06:48 AM   #9
To answer the question, payback takes awhile. You can do the math. Assume savings of 20-30% on fuel bills. On an annual heating/cooling bill of $1000, you can save $200-300, not quite the cost of one quality window-installed. But there is a bonus in comfort. Besides keeping in more heat, drafts due to cold air falling off the old cold glass is gone. Quality insulated glass does not get cold like the old glass did.
Old 08-22-2010, 11:20 PM   #10
Rewards Points: 502
well, I think your season's estimate is a bit low for up here, but I see your point, and thats what I was starting to think too. There are other things to spend my limited resources on first.
I am thinking this will be a farily short term house, so I also have to figure in the claimed 80% ROI for windows too (im not sure it would be that igh in this market), so if we knock up the savings to $500 compared to the cost minus RIO, still not quite there. maybe if some realestate investments I am looking into pan out (current focus is on buy low, really low), that might be a good place to "hide" some money.
but then again, ROI + tax incentive looks like about 90% on paper. that would pay for itself a bit quicker.
Old 08-22-2010, 11:26 PM   #11
We knew we were going to stay here for a while
So it made sense for us
Our heating bill has dropped by ~50%
3 tanks of oil down to about 1.25 to 1.5 tanks
And that was when we were keeping the house warmer due to my son being born
Old 08-23-2010, 12:02 AM   #12
Registered User
Take into consideration the average sized window in that average room may be 15 square feet. The two exterior walls, 8foot high and 10 feet long (minus the window) total 160 sq.ft. Add the ceiling- 100 sq.ft, equals 260- s.ft. IF the walls are now empty, and you insulate them (R-13) and add to the attic insulation, doubling (R-20), you could have R-33 over 260sq.ft. OR R-2,over 15 sq.ft. Which would be cost effective...... which would be warmer... I'm just saying: do the math and the research first. http://www.ecohomemagazine.com/energ...gy-claims.aspx
Be safe, Gary
Old 08-25-2010, 07:50 PM   #13
Rewards Points: 410
I didn't put new windows in the last place I lived just because I knew I'd
never get my money out of it in the neighborhood I was in.
Comfort wise I probably should have because to get the humidity high enough
in the winter condensation would form on the glass.
Nose bleeds ( Me ) from too dry of winter air are no fun and neither is water
dripping on your windows.
Health can be a factor also.
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
