Window Trim - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2010, 04:00 PM   #1
Window Trim
Hi, our window trims have rotted, we're wondering which would be better--wood or metal trim? Thanks!
DavLaurel is offline   Reply With Quote
Old 06-27-2010, 05:24 PM   #2
Drywall contractor
Rewards Points: 1,068
Assuming you're talking about outside trim (brick mold, sill, etc.) you're best off with composite (PVC/plastic) trim. If it's inside, you need to figure out where the water is getting in and address that situation. Then replace with new wood trim.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-27-2010, 07:06 PM   #3
I should have specified that the rotten trim is outside. Things are fine on the inside. So the issue is whether we should stay with wood or switch to metal. I understand metal trim lasts longer and is virtually maintenance free.
Old 06-28-2010, 08:15 AM   #4
Drywall contractor
Composite. It lasts "forever" too. Available at HD or Lowes....
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Window Replacement and Trim Red Truck Building & Construction 3 02-11-2010 11:13 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 10:31 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 09:49 PM
