Window Screen Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 12:13 PM   #1
Window screen question
Some of the windows on the house I just bought didn't have window screens. They're double hung windows. How would I go about getting replacement screens? Thanks for the help.
timothy918 is offline   Reply With Quote
Old 04-28-2010, 12:16 PM   #2
What Mfg window ?
HD carries Andersen & others; Lowes carries Pell & others
If you know the Mfg you shoudl be able to buy some
Or a store may be able to make some
Old 04-28-2010, 12:28 PM   #3
Originally Posted by Scuba_Dave View Post
What Mfg window ?
I couldn't find any kind of mfg id on the window frame. any idea where else I could look for an mfg id?
Old 04-28-2010, 01:38 PM   #4
Household Handyman
Rewards Points: 1,408
From experience: You may have to find a local "Window & Screen" type business to make your screens. If you have to go that route, you may want to consider going to storm windows. These would offer some insulation value and would definitely offer protection from the elements. I have found the pricing between having new screens only made and storm windows made to be little difference. Our local Window & Screen shop offers screen frames in colors to enhance the windows, and they also offer the storm window frames in the same colors. Just a thought, David
Old 04-28-2010, 04:26 PM   #5
Thanks for the suggestion. I only need screens. This is a 3 season porch. I am going to check that option out. I only need 3 screens. Shouldn't be to expensive.
Old 04-28-2010, 04:43 PM   #6
You could also buy screen material & make your own
Myself I'd go the storm window route
Even a 3 season porch with storm windows will stay warmer & keep the house warmer - if you are in a cold climate
If the windows face south the storms will work even better in cold weather
Old 04-28-2010, 09:26 PM   #7
Is there a how to on making screens? What material do you use for the frame?
Old 04-28-2010, 09:36 PM   #8
A simple frame would be out of wood, depending upon size
Old 04-28-2010, 09:42 PM   #9
I was just doing some searching on the web. There are kits you can buy that come with the aluminum channel, plastic corners, the spline.
But I like the wood frame idea. Thanks
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Another window installation question edwood79 Remodeling 3 11-15-2008 02:14 PM
window installation question boydbuild Remodeling 4 11-15-2008 06:51 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window Question? joan2020 Building & Construction 1 09-16-2006 07:11 PM
