Window Replacement Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 08:40 AM   #1
Question
window replacement question
don't know which sub-category this fits - so I'll start here.
finishing a year long basement gut/remodel and last to go will be 4 single pane hopper windows. have had a couple people look at the windows - this is the one job I'm not touching - it's getting colder and just want it done
one company claims they will install a vinyl window from the inside - without removing existing aluminum frame and this doesn't quite seem right to me so I wanted some advice from anyone who may have a bit more experience
thanks in advance
qchawkfan is offline   Reply With Quote
Old 10-16-2010, 09:10 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can do it that way,would depend on what you want and how the old unit is burried in the masonary,i like to see total removal if possible
post some pics if you can
Tom Struble is offline   Reply With Quote
Old 10-16-2010, 09:39 AM   #3
here is what I did last fall - I cleaned it all and made it look better/finished
you're asking - why didn't you replace the windows then? it wasn't in the budget at the time...
window replacement question-windowbefore.jpg   window replacement question-windowafter.jpg
Old 10-17-2010, 04:21 PM   #4
Rewards Points: 5,336
It's possible to use the old metal frame as a "stop" for the new window if need be. The issue would be the sill area. The new window will have drain holes for water to get out. These need to be open, so the old sill frame would need to be removed or modified to keep the drains open.
Ron
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 11:20 AM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replacement vinyl Windows (Measurement / ordering question) DyerWolf Remodeling 5 10-02-2009 08:54 PM
Picture window replacement...help! feido Building & Construction 6 07-09-2009 07:02 PM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 03:59 PM
