Window Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-03-2006, 11:25 PM   #1
Window Problem
Hi All,
Two of the windows in my house dont "stay up." They slide up as normal, but then slide down either half way down or lower. These same windows also get foggy on the inside as well, and accumulate drops of condensation.
Is there anything I can do to fix these w/o having to replace the entire window??
Thanks!
LS
lockstock is offline   Reply With Quote
Old 07-04-2006, 08:08 AM   #2
Are these isngle pane windows?
Do they have weight ropes on the sides?
redline is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 11:06 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
Window doesn't slip well Not Sure Building & Construction 3 08-12-2006 09:12 AM
