Window Leak - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 11:53 PM   #1
window leak
Hey everyone-
I bought my house and discovered water damaged behind the paneling when I took it down and cracking on the plaster wall. I thought it was old damaged so just patched it up with some mud. However, now it looks like it's coming back because the mud is discolored along the same lines...so I'm thinking the window is still leaking. Unless its possible the stain just bled through? Attached is a pic of the wall...I'm not very familiar with window leaks so maybe someone can tell me if the pattern is typical of a window leak or maybe I should check out the roof. The mud you see on the wall is about a month old and as you can see its discolored in the same way as the paint (which was like that when I bought the house). The caulking around the window and the outside of the frame is completely shot. Is this hopefully all I need to do to fix the window in people's experience or is there something else I should check out along with it. There's also a vent for the attic fan I'm thinking could be a suspect. The entire window is under about a foot overhang of the roof.
Thanks!!
Greg
c00rdb is offline   Reply With Quote
Old 03-01-2010, 12:33 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
could be the gable vent leaking or the top of the window hard to tell
Tom Struble is offline   Reply With Quote
Old 03-01-2010, 07:00 AM   #3
I have to assume that this has been leaking for some time??? I doubt it is the attic vent, too well protected by the overhang. The house has been resided, so I am going to guess that the flashing over the top of the windows was removed or not done correctly. Only one way to fix that, remove the siding and redo flashing. Another possible place might be the caulking around the replacement window frames where they join the old window frames, sides and bottom. I do not think the siding/trim capping caulk is a likely spot.
Old 03-01-2010, 08:08 AM   #4
MJW
Looks like the ole jerk, set, and wrap that alot of the insert window guys like to do. It looks like there are multiple layers of siding there. There are many openings that are relying on caulking to keep water out. It could even be a big moisture problem inside.
Someone obviously tried a "flip this house". My advise is to get a good Contractor to fix this house for you correctly and not mess around.
MJW is offline   Reply With Quote
Old 03-01-2010, 04:46 PM   #5
So I'm guessing the consensus is that this is not a DIY project? What is the difficulty of removing and re-attaching the siding? Attaching the flashing seems fairly straightforward. The only thing that makes me nervous is that the problem is on the second floor.
MJW could you elaborate on what you mean by "jerk, set, and wrap"?
Old 03-01-2010, 07:21 PM   #6
by that stain location definitely could be the vent may look protected but..
i would start at the top and start pulling siding down only way to be sure
if it was from around the vinyl window most likely it would be stained directly
below the stool
Old 03-01-2010, 10:59 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
As shoddy as that window install is, I agree with tom that normally you'd have water issues showing up directly beneath it, not a foot or two to the side of it. I've seen stranger things, but not often. Just to address something you said originally, it is likely that the originally staining just bled through the mud, however unless something was done to fix the issue, your leaking is probably still occuring.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-01-2010, 11:10 PM   #8
Actually there was a lot of damage beneath the window...more than to the side. I patched that up with thicker mud since the entire top layer of the plaster cracked off. I haven't seen anything bleed through with that yet though, maybe because it's thicker. I guess I might have to call a pro to fix the flashing, I'm a little nervous working with the siding high up when I've never done anything like that before. :-( There are little tiny cracks where the new stain is so I'm guessing it's still a problem, even though I've never seen any moisture myself.
Here's an idea of how it looked originally:
Old 03-02-2010, 07:14 AM   #9
ccarlisle's Avatar
Just to give you an idea, we were asked to solve a more minor water leak from exactly the same siding job you have, and were asked to replace the caulking, a common problem up here. 2.5 men, 16 windows, three doors, compressor-driven oscillating tools, a three-floor scaffolding, two days, 12 large tubes of caulking compound, $2200...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-02-2010, 10:07 AM   #10
MJW
Insert windows instead of a totally new window.... You can see that there is no new trim inside or out.
With this installation method, it's not as easy to make the window waterproof. It usually depends on caulking. Also, usually means the insulation and flashing(if any) is still original. You can take a guess how good that is. It's fine for a patch up job, but nothing professional, IMO, even though some still pop in inserts and call it a new window install.
Old 03-02-2010, 07:55 PM   #11
Hmm $2200 seems like a lot just for some caulking, must've been pretty involved because of the three floors. Hopefully this won't be so bad.
MJW thanks for explaining, now I have a better understanding of what likely happened. Sounds like some new flashing behind the siding would end up fixing the issue. How difficult is removing and reattaching the aluminium?
-Greg
Old 03-03-2010, 07:29 AM   #12
ccarlisle's Avatar
Yeah, this wasn't an easy job (there was lots of caulking to remove) nor was it just a simple recaulking. Plus we had to do it quick. They wanted it high quality too so the price was justified.
Once you get a piece or two of siding off, the rest comes off pretty easily but it certainly will involve some damage just because they are nailed into place. It's not like a jigsaw puzzle unfortunately, and although others can confirm this, it's not a piece of cake, But that depends on a few other factors...
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
How to fix a leak under a window? stereomike Building & Construction 3 10-28-2008 05:32 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
