Window Exhaust Fan - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 03:56 PM   #1
window exhaust fan
I am interested in an easy install and remove window exhaust fan. I live in an apartment building. I would like to move cooler air into the apartment so I bought this large Lasko 16" window fan but it was about 2.5" inches too high. I then bought one of those twin fans for the windows but those don't move/circulate air at all. Has anyone build a window exhaust fan? Thanks.
kel456 is offline   Reply With Quote
Old 06-27-2012, 04:39 PM   #2
Rewards Points: 590
Your experience with the twin fan is odd, because I have a very old Lasko twin window fan and it works well. I also have a single Holmes, but it doesn't move nearly as much air. I think the actual CFM varies quite a bit between manufacturers. Keep in mind that if you're using it on exhaust on a hot day, you have to open another window somewhere to get good air flow. And of course, you should reverse it to intake on a cool night to quickly blow in the cool air. Make sure to actually use the extenders.
operagost is offline   Reply With Quote
The Following User Says Thank You to operagost For This Useful Post:
joecaption (06-27-2012)
Old 06-27-2012, 05:12 PM   #3
Rewards Points: 13,968
That's the key, one fan blowing in and another sucking the air out for a cross flow of air. Other wise it's like sucking on a straw with your finger over the end.
If it was not a rental, a whole house fan in the ceiling and proper roof venting would help make the whole house feel cooler.
The correct amount of attic insulation and air sealing the attic also would make a really big differance.
Old 06-27-2012, 09:11 PM   #4
Rewards Points: 6,652
Joe, it is an apartment.
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
