Window Cracked On Its Own - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 12:57 PM   #1
Window Cracked on its own
Hi guys,
I have a weird problem, I've had my house for 3 years now, and in those 3 years 2 windows have cracked. the have not been hit or anything and I dont believe that the casing is too tight as the window opens and closes fine.
What could have caused this?
I have attached a picture of the crack
http://www.diychatroom.com/attachmen...1&d=1236362175
rootdown003 is offline   Reply With Quote
Old 03-06-2009, 02:44 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
most probably a stress crack what brand are the windows?
Tom Struble is offline   Reply With Quote
Old 03-06-2009, 02:56 PM   #3
not sure what brand they are, I just know that they are about 10 years old
what would cause stress cracks?
Old 03-06-2009, 03:00 PM   #4
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
neighbor's kids + snowball = cracked window. snowball melts...no evidence.
My first thought was that there wasn't a gap in the framing and the window jam so that when the house settles, the window takes the abuse. When you said the window opens fine, that shot that idea. Are you sure nothing has hit the window?
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-06-2009, 03:07 PM   #5
hmm i assumed they were newer than that usually you see stress cracks the first year or 2
Old 03-06-2009, 03:09 PM   #6
Rewards Points: 1,910
If the window opens and closes fine then it could be an impact crack or a flaw in the window. Have you checked with the window manufacturer?
Old 03-06-2009, 03:58 PM   #7
I am almost certain that it is not from an impact, because the crack that happened on the previous window was in the same exact shape.
Could it have to do with the temperature changes? I live in montreal
Old 03-06-2009, 04:49 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Have you checked them for square?
Some Possibilities:
1.) Windows too small for the opening (R.O.) = wedged in and stressed.
2.) Downward weight load, from improper header framing = stress.
3.) Cheap windows, or manufacturer defect = contact window manufacturer.
4.) Improper installation: Remove one, and inspect the opening, and the window itself for damage, warping, other issues.
- Build Well -
Old 03-07-2009, 09:15 AM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
Check to see if you can find a label for your windows. They will often have a sticker up above the top sash (somtimes in the header if it is a double hung window) or along the bottom of one of the sashes. If you can find out who made the window, you might be able to get the window fixed under warranty. I assume you may have already tried this when the other windows cracked? As to your question, the way it cracked makes me think that there is some kind of stress from the right side rail, as if it is twisting where it meets the top and bottom rail, making it crack almost from corner to corner. Are these wood windows?
Man of many hats
wrangler is offline   Reply With Quote
Old 03-07-2009, 09:20 AM   #10
Originally Posted by wrangler View Post
....Are these wood windows?
The posted picture shows that they are vinyl.
- Build Well -
Old 03-07-2009, 09:29 AM   #11
Man of many hats
wrangler's Avatar
Rewards Points: 354
Thanks, you must have better eyes than I have. I could not really tell, plus I have never seen vinyl windows with handles or muntins like that.
If vinyl, then I cant imagine there is twisting involved, but possibly stress when tilted in/snapped back into frame? Since they operate freely, I would think it's not from settling or too tight in the opening.
Man of many hats
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 10:31 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 09:14 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
