Window AC - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 08:03 AM   #1
Question
Window AC
I have cathedral ceilings in my living room and was thinking of installing a window A/C on the wall that is adjacent to my attic space that has a ridge vent . Is this OK as far as code and everything else involved ?
RetiredGuy14 is offline   Reply With Quote
Old 06-19-2012, 10:00 AM   #2
Rewards Points: 1,500
My condolences to your AC. I'm sure her husband was a good man.
mikegp is offline   Reply With Quote
Old 06-19-2012, 11:04 AM   #3
Rewards Points: 29
I am not sure about code, but the airflow wouldn't be that good so it would be very inefficient. And you would have to deal with the condensation drain.
cube17576 is offline   Reply With Quote
Old 06-19-2012, 11:11 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
I'd try a mini split.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-19-2012, 12:07 PM   #5
Too Short? Cut it Again!
I would enhance the ability to extract the rising hot air up their with some increased ventilation. Put the cooling unit lower. Hot air rises; cool air falls. The output of the AC unit is going to try to sink.
They make some nice ridge vent turbine units that even generate a bit of electricity should you happen to have a place to store it.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
