Will Keeping The Fan Running Help? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2005, 10:40 AM   #1
Angry
Will keeping the fan running help?
I read that if we leave the fan on the heating unit set to run continuously that it will help with my humidity problem. Will this also make our electric bill go up?
Some kind soul, help me out here. :confused:
Sleepwalk is offline   Reply With Quote
Old 02-09-2005, 12:16 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Not sure about the humidity, but you can be sure your electricy bill will increase
Old 02-17-2005, 01:34 PM   #3
Carpenter
DecksEtc's Avatar
A furnace service guy years ago recommended that I leave the fan on all the time. He said that the air circulation helped to circulate the warm air and thereby the furnace would fire up less. It's a hard thing to measure but it seems to make a bit of difference. I don't think furnace fans pull a lot of power but maybe a HVAC expert will see this and add their comments.
DecksEtc is offline   Reply With Quote
Old 02-17-2005, 03:05 PM   #4
The fan itself will not pull too much extra power, but seriously decrease the life of it. If it was designed to kick on for a couple of minutes every hour, than you are talking about running it 20-30 times longer than it was designed to.
bountyhunter is offline   Reply With Quote
Old 02-23-2005, 07:43 PM   #5
Send a message via MSN to Benhamcarpetguy
I always heard the H/VAC system reduced RH levels.
Don
Benhamcarpetguy is offline   Reply With Quote
Running CSST outside to grill on deck... tigerbalm2424 HVAC 6 11-06-2008 11:07 PM
Freedom 90 furnance not running reliably from generator jrielsky HVAC 6 02-12-2008 02:48 PM
Running New Coax modena Home Theater 3 07-18-2007 02:18 AM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
